PM me if you want a custom one designed & made up for you.
I'm an Industrial Designer linked with a carbon/glass/kevlar fibre company. But we need a straight bonnet to rip a mould off first before we can start modifying it. Or just make a standard one in FRP.
Oh, & I just noticed you are in Melbourne. We're in Sydney which is a bit more hassle.
Ben
https://www.sau.com.au/forums/topic/50028-carbon-bonnet/#findComment-995600
www.customcarbon.com.au
Quality is good ,prices are reasonable....do not confuse these with those from UAS,Carmate etc. These are a carbon fibre foam sandwich construction and are 1/2 the weight and 10times as strong.
https://www.sau.com.au/forums/topic/50028-carbon-bonnet/#findComment-995790
Ben
i'll donate my bonnet for experimentation, for a freebie in return :cheers:
https://www.sau.com.au/forums/topic/50028-carbon-bonnet/#findComment-995890
I am currently in the process of getting a www.customcarbon.com.au bonnet as we speak. It is genuine custom carbonfibre item, only 6mm thick and around 6Kg light I'm told(R33 gts-t bonnet 27kg). If you want to see it i'll have it on my car just before my car enters with the SAU stand @ autosalon in melb, sept 18-19.
there a little more expensive than the UAS & carmate bonnets, but thats because there the real deal, not just a carbon top layer with fibreglass under. Plus if your like me, with a series 1 R33, then theres only one (UAS & carmate) vented bonnet style, which I dont really like. so custom was the only choise for me :cheers:
https://www.sau.com.au/forums/topic/50028-carbon-bonnet/#findComment-995996
Ben
Ooooo! You live in Leichhardt, like me! :cheers:
What is the name of the business you work for and where is it located? I might be looking to have some C/F bit fabricated in the future/
Lucien.
https://www.sau.com.au/forums/topic/50028-carbon-bonnet/#findComment-996005
Lucien,
Its a very new company called Sweet out at Penrith. They have done a few things like bumpers/bars, engine covers, air scoops, some std bonnets & a bike fairing. The owner has been working with FRP for years & recently turned his skills towards cars.
They are currnently doing their first full custom bonnet for a guy who is entering his car in Autosalon so hopefully their work will be on display there.
Will post up full details when I've got them to organise advertising and so forth in a couple of weeks.
Ben
https://www.sau.com.au/forums/topic/50028-carbon-bonnet/#findComment-996650
there a little more expensive than the UAS & carmate bonnets, but thats because there the real deal, not just a carbon top layer with fibreglass under. Plus if your like me, with a series 1 R33, then theres only one (UAS & carmate) vented bonnet style, which I dont really like.    so custom was the only choise for me :P
Are you getting one like the pic in thr gallery of the r33?
If so, it looks rather plain compares to the UAS and Carmate ones
https://www.sau.com.au/forums/topic/50028-carbon-bonnet/#findComment-997590
same vented bonnet as in there gallery, with extra vents behind radiator for cooling (kinda like the VeilSide bonnet). As far as looks go....yeah i guess its a little plain, but its the real deal and different.
Plus as mentioned earlier......only 2 choices for SERIES 1 in jap (carbon top fibreglass under) carbon bonnets, plain with no vents, or butt ugly raised vents right at the front of the bonnet. no thanks, not my taste.
The second one mentioned looks ok in the pic on UAS, but seen on an actual car..........
anyway, each to their own, I like to have a few things a little different from the norm. I'll be sure to post some pics whens its on....maybe even a poll? hehe :rofl: or let me know your thoughts at MAS
cheers
https://www.sau.com.au/forums/topic/50028-carbon-bonnet/#findComment-999308
    • Yeah they charge a little extra for mods , last year I noted no mods but I did have an exhaust fitted after that so  better to let them know cause these kinds of things can cause the policy to be void if you ever need to claim.
    • Hello, just just bought an 1999 enr34 with a stock rb25neo and I'm looking to upgrade the engine to 500whp I know some basic things but wondering if there are things I'll need to do to upgrade the stock block and all the bits and pieces to achieve this.
    • Thanks everyone for the replies and suggestions. Got the seats out (hoping I could find some existing grommets but no such luck). By tapping and measuring etc. I could figure out where I could drill through if needed. But first I borrowed an inspection camera and managed to go through factory holes in the chassis rail and could see that the captive nut was holding steady which is why it could retighten. So it was indeed a stripped section of thread, so I applied downforce by levering the bolt head with a screwdriver and went slowly back and forth until it came out. Camera helped a lot cos I could monitor that the captive nut was holding tight. Now I just have one very seized main subframe nut to tackle 😅
    • BOVs do have a purpose, if you ever log pressure before and after the throttle body, you will see a spike pre throttle on lift off from a WOT condition. Enough to bend throttle blades / damage e-throttle motors or simple assist in blowing off cooler pipes. FWIW, the above on really applies to those running at least 2 bar of boost. OP shouldn't have an issue, on the other hand, here are some videos of my shit box over a decade ago with some succulent dose with the airbox on and off. That shit box is unrecognisable these days 🫠
    • I've tried all different combinations of BOVs/ no BOV and stock bypass valves over the years, on gear changes the stock bypass valve seems to get the car back on boost quicker because in part the turbos wheel speed isn't being slowed down by reversion, although they have issues holding boost much over the stock setting. Most aftermarket BOVs you can adjust the spring, tighter will make it open later and close sooner, but in my experience it'll cause a bit of flutter at low load/rpm anyway. I've also got some input into this whole no bov causing turbo wear, never had an issue on any on my turbos HOWEVER, I got my R33 GTST with 200k kms on it, with from what I can see still has the original turbo, no lateral shaft play but has about 4-5mm of play in and out which to me seems like a worn thrust bearing from years (100-150k kms?) of turbo flutter running no bov, so maybe there is some truth to it in the long run. But that'll never stop me loving the Stutututu while I have the car.   OP just wants to know if he can run a atmo vented BOV with no major issues and the answer is YES, plenty of people do it, there's no harm in installing it and seeing how it runs before spending $$$ on an aftermarket ecu, last time I bought a Nistune it was $2400 for install and a tune , unsure of todays prices but you get me. Crazy money to spend just to fix the minor inconvenience of stalling that can be overcome by letting the revs come down to near idle before putting the clutch in or a little bit of throttle to avoid it. You're better off leaving the ecu and tune for after a bigger turbo/injectors have been installed to take full advantage of the tune and get your moneys worth.   Let OP have his Whoosh sound without trying to break his bank haha
