What is the difference in performance between plumb back and atmospheric valves?
M240i xDrive is the way. 3litre straight 6 coupe w/single turbo, ZF8, Rear biased 4WD. It's more Skyline GT-R than the R35 by miles.
I suspect 550s are on the large side for happy operation with a stock/Nistune RB20 ECU. The Hitachi ECU doesn't love short pulse width operation, and the RB20 doesn't need much fuel at idle. Big injectors can be unpleasant. This could be contributing.
Yeah, I still don't know why the idle speed control can't catch the falling RPMs. In the Consult logs I see the AAC duty cycle rising, but suddenly it goes lean and the engine stalls. Anyways, the relevance here is the DW 550cc injectors are probably the same. So if OP has similar issues I would be tempted to finger those injectors as problematic for whatever reason vs the ECU failing for some reason.
