I tried the swap on sunday unseccesfully....
Changed them without any problems, checked everything was the right way, i even had a copy of the GTR manual to guide me thru.
But when it came to starting it would start up and idle very bad.
It was very lumpy and it wouldn hold idle at all. I played with the PFC ign/inj adjustments, but it didnt make much difference.
At one stage it stayed idling but it was very rough. I also noticed that the boost gauge was only showing very little vacuum about -5mmHg.
After alot of frustration we started thinking it could be the valves are already opening as the RB26 cams are 0.1mm thicker than the RB20s at the lobe. Which in turn will push the the valves 0.05mm open.
I still dont really understand the hydraulic lifters concept and how they work. As i understand it when the lobe is pushing down the lifter it is solid as the oil cant escape and when it comes up it fills up with oil untill it gets pushed down again.
So i suspect what might be hapenning is that putting the RB26 cams straight in without taking the oil out of the lifters will make solid and thus opening the valves, and then never fully closing as the oil cannot escape fully.
If thats correct that would mean that before putting the RB26 cams in one should empty the oil out of the lifters.
Im not sure if thats right, but if someone can clarify the lifter operation that would be great.
RB20 cams are back in and everything is fine again....
https://www.sau.com.au/forums/topic/50069-rb26-cams-in-rb20-didnt-work/
  • Replies 100
Sorry to hear it didnt work!
you have had the exact same problem as 4 of us who have tried it. has anyone here bolted in some HKS or Tomie items into their RB20 yet? i dont understand why they should work as a bolt in, yet the GTR ones cause so many problems...
How did you come to measure / identify they are 0.1mm thicker? What / where is that a measure of?
They work for me. i made sure to soak the lifters in oil for a few hours before i installed them.
are u guys sure that you don't have any vaccum leaks, as i have just rebuilt my engine all hoses with new hose clamps and all, the went to tune it and it wouldn't idle. ended up being that nearly all the hoses on the intake manifold where leaking. (yes they were tight)
Roy: It is measured at the heel of the lobe the flat section with no lift.
Ahh32: Why did you soak them in oil??
WazR32GTST: Can you confirm that your mechanic actually bled them before he put them in?
Im still not convinced thats the reason why they havent worked. Maybe Sydneykid can help here ...
i can confirm that my mechanic bled them
when i picked the car up he said to me that he bled the lifters. not sure if he did it because they were noisy with the old cams or that this is a standard protocol for a cam change. either way i am 100% positive that this was done.
Waz.
I dont' want to sound like a spoil sport - but whoever put GTR cams in their car and had it idle didn't use GTR cams. You got ripped.
The reason that GTR cams don't work without going into too much detail is that mechanical cams (all GTR and R34 GTT) have a linear lift ramp which in a GTR is app. 0.55mm high and takes something like 50 degrees to reach that point. In a mechanical cammed motor the clearance should be set at the point where the ramps meet the cam lift. (at hot running) So in a GTR, the tappets should be set at about 0.5mm, but Nissan recommend a smaller clearance which not only makes the car sound tough as (as GTRs do) but allows for a lot of valve growth (which GTRs do).
IF you run the GTR cams in a hydraulic cammed motor, you end up with cams that have about 360 degree duration on the seat instead of about 240! This is utter stupidity and should not be done. I am not taking a slash at the people who have done it, but at the people who say it is good and can be done. If it does not make complete sense to you, don't worry it takes a while to get your head around, and I can draw you a picture one day if you want.
Luke
Sorry I phrased it wrong. GTRs have a lot of valve growth and this is characterised by their larger than normal ramp sizes. Honestly I think they specify their clearances to be so tight purely to make the GTRS sound tough. And man does it work! If you run the 'right' clearance in the GTRs it would sound a lot more sedate on idle and low speed running but still make the same HP.
hmmmm dunno bout that.....your meant to run them as tight as you can get them....well this is the case in motorcycle racing,but they get pulled apart every race so i guess that wouldnt work in an everyday situation....i have also noticed that the inlet valve has a larger clearance than the exhaust(which is opposite to the way it normally works)one would assume that this would be due to the sodium filled exhaust valves that RB26s have....
i have never seen Nissan clearances. I know what they are meant to be because I have cam doctored GTR camshafts, plotted them and found out what clearances are needed to run them at. Noramlly you put 0.05mm more clearacne on the exhaust to accomodate growth. Anything half decent runs Inkinel (spelling) or sodium filled exhaust valves. At the end of the day who gives a toss? GTRs have big ramps and need larger than expected lash settings. Nissan set them closer than they need to be. I bet they didn't set them at this setting for emissions testing but...
If you are a hard core racer, you set the tappets wider than usual and you eat valve springs, but thats the price you pay for HP.
Do not run Solid camshafts in your hydraulic car. Its not fair to people like jnr32r who take your word and end up wasting their time and money trying it. Try to keep the BS to a minimum and this will be a nicer place.
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
