52 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Might want to keep in mind there might not be any more 15y.o. imports after the end of the year, so surely a car like that would then be even more expensive? Just garage it, at least you know you're going to have something you like this christmas! :D
thats if that goes through...
good point tho.
  • Replies 94
doughboy has a good point.. either sell now for big profit.. and then with the savings ship something else over b4 the end of the year.. if that is shit, flog that off for profit again.. if not keep it.
Can't lose either way...
edit: actually get 2x cheapies, and keep the one that arrives in best condition :D
keep it Ni, U'll regret selling it...
By the way, I know somebody that has a tow truck that can cart it  around for ya......:D
lol serious? can i have his number??? :(
don't sell the car nark, just keep it for however long it takes. Just remember that you only got that car because of some favours that got called in (originally that car was goin to perth) and gettin another like it is pretty hard.
Also when you get that car you don't just get that car, you also inherit an ex tuning house car, AND the owner is keen on coming down and seeing it soon as well.
Look man half the guys on this forum have financial problems, me included. If you really like wht you have then you work around it. I've put off putting an RB25 in my car for yonks, but now I have the $$ to buy one so I am. Its taken me close to 6 months.
If you really need money that bad let me know how much and I might be able to loan you some.
that thing shitbox everyone say is nice just to make happy you.
sell it chip 10,000$ and buy big trailer with mota.
Your a fcktard...go away and learn how to spell....and your post doesnt make any sense......could it be MD?
    • CTIS (Central Tire Inflation System) has existed since the 80's. I'm looking into buying a Hummer H1 and they generally included it.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
