  • Replies 85
If we get a refund then yes. It won't rain.
Yes will be aiming at that time Duncan. Yes just needs a screen and one of the intercooler tanks replaced. New brakes are great and engine is crisp and strong and survived an absolute thrashing from me. I drove it like it was stollen and the Drift Nationals.
The two GTR's from SSS Automotive will be there and it will be a battle with the zed for sure.
Also Gary who did not quite make our last day will be there with his R32 GTR race car with the Holinger Sequential and 320rwkw and a very good driver.
... New brakes are great and engine is crisp and strong and survived an absolute thrashing from me.
:whackit: ...ooh, ooh, tell me more! I would come and have a looksy but im in Melb. Was even looking at your old setup, but i would need 355 or 330mm rotors...as soon as my engine woes are over (next fortnight) me want batty boy brake setup :whackit:
I sold the AP Racing 6 psitons with adapters and 365mm rotors on specials for only $2300 delivered to Melbourne with new coated nuts fo bolts for the alloy hats and skimmed the rotors. I guess you did not want to know that.
Now have same size 365 but the race car three heat and freeze treatment process that make the rotors and pads work and last much longer and they don't warp. Lighter Porsche Mono block 6 piston callipers and Ferado race pads with new teflon lines and lighter billet alloy adapters. I need bigger brakes for the back now with in cabin bias adjustment. Low 47 secs Oran park on the way.
... as i am scared of losing money re: rain
:D Others may be thinking like that so gives you more track time as less cars :( Seriously, the rain isnt all that different from the dry in that you still have to drive withing your (and the cars) limits. Just means you have treat your car like a 450hp RWD monster and you have to use some grey matter when pressing the pedals :(
Please do not mention the blind dogleg as a bad thing, I find there is nothing better than flying over the hill and skeeting across the grass. Fun. Count me in one refirbed turbo in. i gave it a thrash last nite and will be doing it again tonight to be sure i did the nuts up tight..... I`ll still have a set of mismatched suspension tho so if you think body roll was bad you should try driving on three wheels 90% of the time. see yas on sun
Just to let everyone know we are getting heaps of interest in this one. Thanks again for everyone's support and promotion to helps us keep running these days by covering costs.
This one will by far be the biggest roll up of big gun GTR's ever. I will mention a few that are coming. The yellow SARD R33 GTR, Geoff in his Gibson powered GTR which was on our dyno today and puts out some mega torque, Joe also from SSS automotive with his 3 litre bottom end and top mount turbo's monster, Gary with his red R32 GTR race car that just missed having ready for our last track day with Hollinger 6 sp sequential, 240's etc, Daniel in his well set up white R33 GTR and more. Then Jacky with his S15 and very good driver should be top contender, B Man with his touch R33 GTS-T, EVO 7, a 300ZXTT down from Brisbane that does quite a few track days up there, at UAS getting pumped this week but nothing big. Peter from Advan says he has 6 cars coming which I suspect will be trick cars also. Nathan from Grey Imports coming in his Skyline GTR original. My Fat Slot car is all sorted and sorted out at Eastern Creek on Thursday. Oran will do 47 sec or lower.
Not too late to get in but filling fast as have around 30 and max for timing anyway is 40.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
