Trade :- 1992 Turbo N14 Pulsar ***SOLD***
GUYS MY CAR IS FOR SALE AS I HAVE BEEN BITTEN BY THE DRIFT BUG.
its a 1992 silver n14 pulsar
140,000 km on clock
GTIR motor with all guages bonnet and front bar being used - 60k kms on the motor, has around 160kw atw............(with just zost and pod mods done).
The gearbox has been replaced 2mths ago
New organic clutch with springs (suited for wrx's ect... so it wont break) Just replaced tyres with new ones - front cost me $300ea so they are good ones done only 400kms (last ones were 18mths old),
N15 sss brakes (identicle to gtir ones),
3inch zost from the turbo back
17inch 5 spoke rims with king springs fitted.........
LET ME KNOW WHAT OFFERS I CAN GET WITH TRADE OR OUTRIGHT SALE
thanks josh
Josh.. I had a R33 GTS-T with some mild mod... and now I have a car has similar setup as you, but mine is SSS and have some serious suspension upgrade.
Personally I like my current car more... But, of course the Skyline looks better...
The Plusar has 4 doors more practical, use less fuel. But Can keep up with mild mod skyline for sure..... Anyway gl with the sale! :rofl:
Hey mate sell your car first, i've got a mate who is a wholesaler for imports, all legit under the new raws system, can help u get into a r33 2 or 4 door turbo for the right price, would trade but would only give u like 5grand cause what u got is hard to get rid of for the right price, so sell it privately, when ya ready, phone 38811800 ask for craig, and say Justin sent u, or check out some of there cars on the web, www.carmenimports.com
 Share
    • Little more work!  Did some body work on the rear wheel arches and since the paint was a cheap spray job before figured I’d do something to tide me over until I wrap the car.    Colour might not be everyone’s choice but I like it and it’s only temporary, just hate having primer from the wheel arches standing out.    Keeping an eye out for a decent set of wheels to throw on now. Wheels and tires on the car are junk
    • Its likely to be 70% road 30% track usage, track usage will increase if anything. Decided not to fit it as I cant be arsed changing the bushes on my LCAs again 🤣 I did get the below back from GKTech though so they should work together     The anti-squat kit and roll center adjusters work independently since they change the rear lower control arm's angle in different ways. The anti-squat kit adjusts the angle from front to back, which impacts anti-squat values. Roll center adjusters change the angle side to side, mainly to correct geometry on cars that are significantly lowered. They might affect each other a tiny bit, but overall, you can think of them as separate.
    • What are you doing with the car? street car or race car? People get hung up on the squat of the s/r chassis rears. There is positives to the squat if a car is setup and driven correctly for it (correct ride height, spring rate, alignment, damper valving). Generally just lengthen the rear traction arm by 5-10mm and that will help the squat and bump steer too. You are also correct with the roll centre too. This too also needs to be adjustable if you start messing with suspension geometry.   Having done quiet a bit of testing on race cars this year in regards to rear squat, I've seen some big positives from it in regards to drive off corners and traction.
    • I find I am using the MX5 for everything except long overnight cruises with Jackie, or, if picking up the kids to go somewhere, the SS has so much more room inside, and is much more comfortable if your going to be doing Hwy driving for 6-8 hours And the MX5 isn't bad in stop go traffic for a manual transmission car, whilst the clutch kit has been upgraded from stock, it is still light, and also not having a stupidly light flywheel in it helps as well, I've spent alot of time sitting on the M5, M4 and M7 stuck in traffic when plodding around the Greater Sydney Region in it Another benefit is MX5's are not really a car that gets stolen, you can pretty much park it anywhere, and it will still be there when you return
    • I can totally get why you like it for that sort of commute. I was thinking BoganDore because it's such a lazy drive, for things like stop start traffic.   I used to do over an hour in stop start shit from one side of Bris to the next, twice a day. My choice of car was larger displacement, with an auto. Basically for torque in low rpm/very low speed, and no clutch pedal. But loved a fun manual for the weekends, which the partner has (plus had the LandCruiser too for other fun drives). I now have an EV as a work car, and I tell ya what, ultimate daily driver, especially if youre out of energy, like I often am after work. I don't even need to touch the brake pedal   That said, I'm presently rebuilding the Liberty GTB to get it setup for weekend drives and track abuse! So small high revving turbo engine with 6 speed cog swapper!   But for your style of commute, I'd probably take the MX5 too!   For those choices, I'm ignoring fuel economy. Because I know how atrocious V8 daily life is for fuel from when I used to daily a manual SS, ha ha. Hence why I know I love the daily rumble of a V8
