Hey blx and funkymonkey,
If you are in need of a service or upgrades to your car, give us a call at Ice Performance.
We're located in Dissik St, Cheltenham (all the details are in the signature).
We've service and modded many Skylines (GTS-GTRs).
Cheers.
https://www.sau.com.au/forums/topic/5008-skyline-servicing/#findComment-77980
mad... i'm jus thinkin of taking it in to change oils n just to give it a general checkup, hasn't had one since july when it was compliance, and even then it was with JSV, god knows what they did.
I'll contact you sometime next week to arrange a time. PM me cost of general service/oil change if you can.
Thanks heaps
https://www.sau.com.au/forums/topic/5008-skyline-servicing/#findComment-78156
Originally posted by funkymonkey
aw crap... this is what I hate... alternatives... well the Thommo one's closer... guess it comes down to price now. I have heard good things bout ICE tho hmmmmm
And ive heard, and been part of very bad things with manuel. My personal opinion is not to go there.
Im taking mine to ice :)
https://www.sau.com.au/forums/topic/5008-skyline-servicing/#findComment-78239
funkymonkey, u should just do the oil change urself. doesn't take long at all and will save u a shiat load of money. buy some decent oil and change it urself every 5000 or so k's. and then wen its due for the major service take it somewhere.
else some places charge like $75 just for oil change and inspection. not worth it.
https://www.sau.com.au/forums/topic/5008-skyline-servicing/#findComment-79108
anyone wanna tell me how to do it, which oils to change etc? I've always jus fanged it into my favourite service centa (which used to be tuffy's down the block from my house in Epping, NSW, here I dunno anyone.
Anyways, I don't have a garage, so if its too messy n complicated i wouldn't be able to do it. I could get a pan n stuff to drain it I guess.
What do I check every 5000k's n how? it sez on the japanese service manual but i can't read kanji.
Its for a 2.0L N/A r32... I'll probably pop into ICE once I hit 10k coz I really want sumone to give it a thorough check, right now it just needs a minor checkup.
https://www.sau.com.au/forums/topic/5008-skyline-servicing/#findComment-79160
Change oil every 5k no matter what is a good rule to go by. Most ppl use mobil one but there are always alternatives eg insanely expensive royal purple etc etc.
I change my own oil but im not sure hwat actaully happens in a 'major service' any1 knows what actaully gets done plz make a list:D
https://www.sau.com.au/forums/topic/5008-skyline-servicing/#findComment-79179
hey funkymonkey, its real easy, i just did it yesterday and i'm really no mechanic and not good at that sort of stuff, so anyone can do it.
go out and buy some engine oil, (best if u buy it on sale from k-mart or supercheapauto or something like that, u save quite a few bucks) buy the oil filter from autobarn z145a $10.
then let the car cool down a bit and just jack her up and drain the oil and pour the new one in. mite want to let the car down again wen ur draining the oil so that more of it comes out.
check ur oil, its prolly quite black by now if u haven't changed it in a while.
all up cost about $30. cost me around $20 for mobil S (semi synthetic, on sale from k-mart :D ) and $10 for ryco oil filter.
https://www.sau.com.au/forums/topic/5008-skyline-servicing/#findComment-79239
The ryco filters are pretty crappy and i think the authentic nissan filters are cheaper anyhow.
If u havent done it in a while u might also wanna think about buyin a bottle of oil flusher (think thats what the call it) loosens up all the oil so i drains better but it can also mean that u lose all that nice sticky stuff protecting ure engine.
https://www.sau.com.au/forums/topic/5008-skyline-servicing/#findComment-79265
A service once every 5k keeps the mechanic away...
For me and a few mates this is what we do :
5k intervals
Engine Oil with new oil filter
Gearbox Oil
Oil and Clean Pod Filter
Computer Reset (on thos with the stand ECU)
Inspection of pads/rotors/fluids/belts
10k
as above with
brake bleed
new fuel filter
flush radiator
compression test (helps when you mate is mech with all the good tools)
20k
as above again, but adding new spark plugs, new air filter element , brake pads usually
The Nissan 100k is pretty big and needs a workshop
all the above and :
change of all belts, water pump, alternator (?)...not to bad on the 'Lines as they have a timing belt...****ED if your doing it on a SR which has the chain...gggggggrrrrrrrrrrrrrrrrrrr...
https://www.sau.com.au/forums/topic/5008-skyline-servicing/#findComment-79423
Thanks for the help guys..
I have another problem that i hope you can help me with..
One of my fan belts is half the original size (width ways) parts of it are shredding off and I desperately need a new one but no one seems to know the part number.
The belt is (as you look at the engine from the front) the bottom one on the right hand side.
If any one has any idea on the part number please email the email address below.....thanks.
https://www.sau.com.au/forums/topic/5008-skyline-servicing/#findComment-80296
    • 200 cell cat will probably help. Do you have room to tee off a Helmholtz resonator anywhere along the exhaust? These can do wonders for drones, with a little experimentation with regards to length.
    • The car revs up through the gears much better/faster now, and fuel consumption doesn't really seem to have be affected either on a Hwy cruise, which wasn't expected  The FAB9 intake manifold has been problematic sourcing though, I've contacted Plasmaman to ask about their intake, which you can get different runner lengths spec'd, and, their different options for throttle bodies  The only real physical drawback with the Plasmaman intake is how to connect it to my current OEM style airbox, as FAB9 make a OEM style back half of the airbox to suit the larger diameter throttle body, and all that is required is a 30°bend silicone pipe to mate the throttle body to the airbox Car also goes in for some exhaust work in a week or so to fit the biggest resonator they can fit clearance wise in the front pipe to help remove some of the drone, there isn't alot of realestate under there, a rough guesstimation is it will only be about 3-400mm long and maybe 90-100mm diameter, and with a 60mm exhaust that doesn't leave alot of space for the internal volume of the resonator to do its thing I'm thinking I may need to bin the "high flow" 100 cell cat for something a bit more substantial, yeah, and restrictive, like a 200-400 cell, to help, but, I have ample room for a really large bodied cat to replace the current one which has around a 4" diameter body I may look around in the recycling bins and see if I can find a massive newish cat that was "replaced" with some new full exhaust system that the local exhaust shop in Western Sydney is doing
    • Hahah look at that smile 😂 Just like those ones on IG where they compare the husband in family photos vs husband going fishing lol. I don't think I'll participate this time, clutch isn't in and also the last time I went there were too many numpties on the cruise sessions. Nearly caused a few accidents holding up people and a few guys initiating massive kerb to kerb drifts with heaps of cars right behind them. Not to mention, there were guys on the track session using it as a power cruise session.
    • Is there an actual website thingie for peoples who don't have Facebooks? Cheers
