2007 GT-R
From Car and Driver Magazine: Lotus is once again in the U.S. Sports car limelight thanks to the introduction of the Elise. Whats next for this small car company based in Hethel, England? The Esprit replacement? Yes, but before that, we discovered that the company is busy with the upcoming Nissan supercar GT-R.Sources told us that Lotus has been hired to fine tune the car's handeling, with includes developing the suspensin and steering. The prototype car, wears an Infiniti G35 Coupe shell has been spotted numerous times around Hethel this past year.
Nissan alos has outsourced the development of the GT-r's engine to Cosworth, the noted race-engine builder. We hear Cosworth is massaging Nissan's VQ powerplant to produce about 450bhp. Early reports suggest that the 6-cylinder engien will be turbocharged.
So what do we make of all this? Well, it confrims that Nissan is serious about the next GT-R, due to hit show rooms around the world in 2007, and is seeking the help of outside experts to produce what may be the ultimate grand tourer. When the GT-R, which may possibly wear an Infiniti badge, arrives drivers of cars such as the BMW M5 had better keep and eye out. - Sam Mitani (Car and Driver Magazine)
https://www.sau.com.au/forums/topic/50101-2007-gtr/
^^^^^ That article has been circulating around the 'net for ages now... and it's just re-hashed info from '02 anyway (bar the 2007 bit, which was in the press release at the '03 Tokyo Motor Show).
Again, notice the US journo's refer to the car as an Infinity G35... when the actual prototype in England is a V35 Skyline... almost like they couldn't give a shit about the "Skyline" link.
https://www.sau.com.au/forums/topic/50101-2007-gtr/#findComment-996831
    • Thanks mate 👍 The car was brought into the UK by a USAF mechanic until he was stationed back to the US, one owner later I bought her back in 2009. Luckily the only corrosion was on the sill seams, so once taken back to metal and treated and sealed all ok, I then undersealed the car myself and check yearly and treat any corrosion which to be honest is zero. She's garaged most of the time and hardly ever driven in the rain, but as you say most are rotten unfortunately, I was lucky in finding her as she was and still is in excellent condition.
    • Stunning car.  Looks amazing!  You're in the UK?  How the hell do you stop your car rotting away beneath you?  British cars are the WORST I've ever seen in regards to rust.  Some of the cars SR Autobody have done are borderbeyond saving.
    • not a date code? or a foundry code?
    • I have up to date pics of the engine build and turbo conversion over on my instagram @skpro_jects if you want to take a deeper look.   Basically the exhaust manifold is straight bolt on and the ports match (they arent any smaller than a 25 or 26 head).    the intake ports are different shape so the 20/25det manifold will bolt up but wont match properly or seal. You will need to port match using the 25det gasket as a stencil. Personally i ran the entire stock 20neo intake setup and have configured the swirl valves and torque valve to work based on my custom parameters to help with off boost response and spool. But this is using a standalone aem v2 ecu. The stock 20det ecu wont be able to control them.
    • Hi. a little later but if the topic is here. So...the exhaust is the same and you can use 25/Turbo or any aftermarket? What about intake side? Is it too "plug n play" or? (i do not remember for 100% but i think that one intake to head gasket was little bit different than on the RB25 - i bought gasket kit way back) I know that even if it "plug" those butterfly swirls would cause ECU to be confused or?   Just asking for the info 🙂 and of course the RB25 things are easier to come by
