hi all
have a rb20det wiring loom and am missing a connector?
i can only locate one of the wires on the computer pin which is #109 white with black stripe...
the others that i have no idea where they go are
White with purple stripe
White
Brown
Black with red stripe.... (on the computer pin it is a thin wire, but this one is thick - is it the same one?)
thanks
https://www.sau.com.au/forums/topic/50145-rb20det-wiring-question/
W/P is power to the ECCS &/or IGN coil relays (green ones in behind ECU)
W is power out to IGN coils
R/B is ignition power to ECU (pin 45)
Don't recall what the Brown is for, but might be power to O2 sensor heater.
Pin #16 (orange wire) switches the ECCS / IGN coil relays.
White runs from the IGN coil relay output to the IGN coils.
The sequence of events appears to be:
Ignition switch powers ECCS pin 45.
Pin 16 is switched to earth, and switches the ECCS & IGN coil relays.
The ECCS relay supplies power to the ECU thru pins 49 & 59
The IGN coil relay supplies power to the coils, thru white wire
