APEXi EL Meter II Series
60mm Boost Gauge White face $250
60mm Water Temp Gauge White face $250
both come will all stuff needed to install
Also will require APEXi EL II Series Control Box to plug gauges into $100
Or the lot for $560
Pics will be available over next few days
hi, im keen on these gauges, do they coem with the stands, or is it the pillar mounts?
can you send pics of the gauges n parts that have been pulled out of the car to [email protected]
thanks
they come with brand new stands and all the cables, manual (in japenese) and everything needed to install them. english manual can be obtained from apexi website
may have time to get some pics of cables etc but i believe they will be sold before i post any more pics
i couldnt find the series 2 gauge english instructions on the apexi usa site?
    • Bringing an old thread back to life Looking to put some new front shocks in the r33Gtst and the KYB still look ok for a road car. Unless there are any other options aroind that price $200 a shock?  I’d like to replace the strut tops also, is this the correct KYB no. For the strut top, KSM7124?  https://www.sparesbox.com.au/products/kyb-strut-top-mount-ksm7124?srsltid=AfmBOoq-HDru8wSlLnQrhU9gCw_uYdKg8gUQzONY-EQOdnI5iXOWEUjY 341287 appears to be the front KYB shocks part no.  thanks all
    • LandCruiser used to get a fluid flush every 12 to 18 months.   Only because it was about that often the electric motor on the master for brake assist kept dieing and needing to come off.
    • Best practice for any track day should be Bleed brake fluid, inspect rotors and pads maybe even flip pads if they are prone to tapering.  Quality pad (project mu, endless, hawk, winmax, ap), Good high carbon content rotor (dba4000/5000, Ap, projectmu), Quality fluid, Good air supply over the rotor and caliper are all required for best performance at a track day no matter the car.  Even the bedding in of the pad and rotor is key to longevity. I've seen so many rotors destroyed on their first track day due to it.
    • The hardcore tracks1ut guys I know would flush their brake fluid every 6 to 12 months depending on the amount of track work they did. Unlike most of us SAU guys, probably flush it once a decade 🥲
