Mods...both
Performance...GT-t mainly cause engine will be newer lol
Handelling...not sure
General performance...not much in it lol stock wise
Im selling up at the end of year to buy a 34, 33's are nice but they are getting old man. and they are as common as dog shit now
34 stockies go for low 30's...
33's range from shit ones...mid 10's to nice stockies high 10's and reasonably modded low 20's depending on whats on it
https://www.sau.com.au/forums/topic/50175-r33gtst-or-r34gtt/#findComment-997998
Guest RedLineGTR
From being in both type of cars. Depends how much money you want to spend. In those budgets I would only consider a "late" series 2 in the r33 gtst range at a minimum if you wanted a r33 otherwise I would say get a r34 gtt all the features, added options, cosmetic looks, performance etc all add up to the price of the R34 gtt and is worth every penny.
My 2 cents. Rob
BTW Your the one who will be sitting in the car most of the time (unless someone else uses it) try a seat in each car and which one your are more comfortable with.
https://www.sau.com.au/forums/topic/50175-r33gtst-or-r34gtt/#findComment-998010
I looked at both when buying my skyline and the 34 is definitely worth the extra price.
Whilst fundamentally the same, the extra refinement and newer age are a big plus. And also as previously mentioned 33s are getting very common, whilst there are a few 34s out there, nowhere near as many.
https://www.sau.com.au/forums/topic/50175-r33gtst-or-r34gtt/#findComment-998076
the neo motor has solid lifters and it's factory power rating is higher than the 33.
the only bad thing is 2nd hand parts is hard to come by with things such as suspension parts, body parts, interior dress up stuff etc...
but i thought it wasn't as easy to tune and doesn't take mods as well
https://www.sau.com.au/forums/topic/50175-r33gtst-or-r34gtt/#findComment-998124
I think I will end up saving for a R34, the do produce a nice torque band stock and are modify-able.. Just a little more pricey at the moment, but I'm sure they'll go down as time goes on, I'd love to do one like the one in your avatar torreto, or perhaps a black one..
https://www.sau.com.au/forums/topic/50175-r33gtst-or-r34gtt/#findComment-998372
33 -> cheap, everywhere
34 -> newer, better and more torque engine, cool styling (at least in my opinion anyway), not as common as 33s, nice dash, more boot space and also more backseat room :D The only downside is the price.
Ultimately the choice is yours, I have test driven a few 33s (modified and unmodified) and a few 34s. At the end the 34 is what I did purchased, I would go so far as to say that the 34s can be used for a family car quite nicely. :(
https://www.sau.com.au/forums/topic/50175-r33gtst-or-r34gtt/#findComment-999076
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
    • That's not very Toyota of the Toyota!
    • Bringing an old thread back to life Looking to put some new front shocks in the r33Gtst and the KYB still look ok for a road car. Unless there are any other options aroind that price $200 a shock?  I’d like to replace the strut tops also, is this the correct KYB no. For the strut top, KSM7124?  https://www.sparesbox.com.au/products/kyb-strut-top-mount-ksm7124?srsltid=AfmBOoq-HDru8wSlLnQrhU9gCw_uYdKg8gUQzONY-EQOdnI5iXOWEUjY 341287 appears to be the front KYB shocks part no.  thanks all
    • LandCruiser used to get a fluid flush every 12 to 18 months.   Only because it was about that often the electric motor on the master for brake assist kept dieing and needing to come off.
