  • Replies 59
Wow, nice and clean. You must have polished it recently.
Ohhh, :rofl: you have one of those screens that you can pull back to cover the cargo area... Mine doesn't have one, I've got a import place trying to find me one, but I might take a stab in the dark and see how much they are from Nissan.
What's the bet that's it'll be over $500 new from Nissan ?
J
https://www.sau.com.au/forums/topic/50201-photos/page/2/#findComment-1003365
Cool - I *think* the part number is 84986.. But I've attached a screen dump of the Nissan Fast program showing the parts etc (zoom to 100% and you'll see it propa :) ).
I hope it helps.
J
If somebody gives me a part number on the screen I will a price out of Japan.
Thanks.
https://www.sau.com.au/forums/topic/50201-photos/page/2/#findComment-1012941
seems like my speedo on rsm isn't working, sub zero installed it so im quite confident of its connections. The right wire on the right output, everything else working, ohh.. hang on....my dash speedo works, but the light on the digital odo/trip meter doesn't work when lights on....hmmm. have to check that one out...
Has anyone else got an rsm on their stagey?
https://www.sau.com.au/forums/topic/50201-photos/page/2/#findComment-1014277
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
    • Hmmm interesting. Mine is the exact same and clearly the right one.  The mystery of the engine oil being full after 3.5-4L continues
