  • Replies 59
Mad Wagon. Did you get your RSM sorted out? Do you find that it gets in the way where it is? I have bought one to go on my car when I get it. Can you let me know what the problem was when you find out please? Oh and by the way what size are your rims? I have some 18X9 rear and 18X8 front ones I got in from Ozzy Tyres. The guy said they would fit. I'm starting to think they may not.
https://www.sau.com.au/forums/topic/50201-photos/page/3/#findComment-1021771
__________________
hey burkey22,
just fitted r33gtr(17'-9 +30offset) rims today.... they do sorta fit.. but stick out a little bit.
best fittment for stagea rs-four 17" or 18"-8 +30offset ( tested n proven )
https://www.sau.com.au/forums/topic/50201-photos/page/3/#findComment-1022594
I was talking to a mate of mine in Japan because we're looking for TE37s and he came back with this:
> I called the parts shop to specify the parts about Rays Volk TE37 Size is
> 17x8.5 30/40
> They told me this alloy has 2 types. they are 30/40
> If that Stagea is customized as low-down, the wheel size suppose to be
> 17x8.5 30/. However the alloy may scratch the fender of the car.
> If that Stagea is not customized, the wheel size suppose to be 17x8.5 40/
> However it may scratch the inner of the car
> The Parts shop adviced me that Ray Volk TE37 has other types.
> They are 17x8J 33/38 33 is for low down and 38 is for normal car.
https://www.sau.com.au/forums/topic/50201-photos/page/3/#findComment-1036711
One point of advice I was given when i got mine was just like the GTR u should keep the same rubber front and rear or they scrub out coz of the 4wd.  GTR offset seems to be +40.
Keeping the same diameter front and rear is correct, but width is irrelevant. :)
https://www.sau.com.au/forums/topic/50201-photos/page/3/#findComment-1036868
Thanks for the tip, so same size would be better for rotational purposes only and not so much scrubbing out problem, cheers.
Scrubbing out? That's more of a term I would apply to poor wheel alignment, not different size tyres on a 4wd. Having different diameter tyres on a Stagea will not scrub out tyres, but it will accelerate wear on the ATTESSA 4wd clutches.
Basically what you are looking for is the same rolling diameter of tyres, so;
245/40/17
205/55/16
225/50/16
225/45/17
245/45/16
all have basically the same rolling diameter ~630 mm
An example, if you have say 7.5 X 17 on the front, then 225/45/17 would be OK with 8.5 X 17 on the rear with 245/40/17.
You need to check with your tyre supplier, as diameters vary between brands.
Hope that helps :(
https://www.sau.com.au/forums/topic/50201-photos/page/3/#findComment-1038006
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
    • Hmmm interesting. Mine is the exact same and clearly the right one.  The mystery of the engine oil being full after 3.5-4L continues
