  • Replies 91
Hey, after a number of items:
1. if the strut braces are still available, let me know
2. if no one ends up with the brake master cylinder stopper, and it fits 32GTR, let me know
3. if you want to separate the brakes, I'll have to braided hoses if they fit 32GTR...
Preparing for a track day on the 24th... so need to get the parts in advance ;)
Cheers
Hi Marcus,
1) strut braces have been sold - only items on 1st post are currently still for sale.
2) no idea re. the cylinder stopper's suitability for GT-R, but will let u know if the sale falls through
3) i'll get back to you re. brakes by end of next week - they are still on the car, had a few delays removing them as mate's workshop is busy. There's a bloke who's interested in the lot, will see how that goes first as he expressed interest 2-3 weeks ago about buying the lot. the lines will fit the R32 GT-R's sumitomo calipers - thats what i have on my car that's for sale ;)
regards,
KJ
Hi Marcus,
3) i'll get back to you re. brakes by end of next week - they are still on the car, had a few delays removing them as mate's workshop is busy. There's a bloke who's interested in the lot, will see how that goes first as he expressed interest 2-3 weeks ago about buying the lot.  the lines will fit the R32 GT-R's sumitomo calipers - thats what i have on my car that's for sale  :D
regards,
KJ
Hi KJ, found some brake lines / booster so don't worry about them mate :P
Thanks, and good luck with the rest of your sales!
hi Michael,
I have some interested parties @ asking price at the moment, so that would be the lowest now. just waiting for my mates @ workshop to get off their arse and take the brakes off the car...
regards,
KJ
Thanks mate
hey Matt,
Forgot my camera today, but measured the core - it's 30.3cm or so wide, and 15.5cm or so tall. Other info on the design of the cores is on the Earl's website. I'll try to get pics tomorrow or something.
cheers,
KJ
2" i think.. that's what it says on the website anyways.
http://members.ozemail.com.au/~earls/oil_cool.htm
when you're back in Syd, you're welcome to come by and view for yourself, just send me a msg on 0414671788 and we'll arrange something :D
regards,
KenJi
parts list updated yet again - check first post. pics on first posting have also been updated - added are the earls oil coller kit pics , Blitz/URAS D1 Ltd Ed SBC-iD, and cusco oil catch can.
    • Gas MIG for learning, I was able to weld up some nice 1.6mm tubs so you can do thin stuff easily enough. Then moved on to thick caliper adaptor brackets with the same machine, all good.  Arc/Stick is great for dirty garden work etc, but Gas MIG for starting on car stuff.  Jump on the NCR FB page and search ATP Tubs or GKTech caliper adaptors for pics/info. I'm no pro but it wasn't hard to learn. Be willing to grind and go again though if it's cold etc.
    • That's not a bushing!
    • Oh and I got myself a grandpa spec dash mat.
    • Ok, so first round of maintenance done. I didn't get much history with the car but I know it was well looked after. That isn't enough for me though, so ...  I had to do the oil filter housing gasket. It was leaking a lot, and also as part of that I did the anti-return valve and the VANOS oil line (from HEL).  But, then I got hit with the while-ya-in-there's. Did both accessory and A/C belts, tensioners and pulley. The accessory belt that came off had a huge hole in it, like somebody hung it up with a nail. The pulley and tensioners seem ok, so I'll keep those just in case. I did water pump and pump pulley. The water pump had a small bit of play so timing was good.  I also did fan clutch. I don't know how to test the old one but between the water pump and the fan clutch the car is running a little bit cooler (not much ~2 - 3 degrees maybe) so good result. Unfortunately the thermostat and housing didn't turn up in time so I'll shelve those. I have no concerns at all on the current ones.  Then I spent what seemed like 40 days and 40 nights bleeding the air from the cooling system. She also got new air filter, fuel filter and did a Mobil 1 change with oil filter. Hilariously, not an hour after telling my wife how proud I was of myself to be going slowly and meticulously and making sure everything was torqued and nothing missing I went and started it without the oil filter in. The car complained immediately of no pressure and after only a few seconds I turned it off and discovered a shit tonne of oil on the driveway. Sigh. I've driven it since and thankfully doesn't seem to be any problems. AND THEN during the test drive a ratchet extension fell into the battery area in the boot and JAMMED right next to the positive terminal and the car body. Like, just touching it made sparks and it was jammed in there. So, almost killed the engine and then almost burned the car to a crisp. Good start. This was the rails under the splash guards. So stoked, she's straight as and super clean. No rust anywhere. There was a heap of caked dirt that I removed but otherwise looked great. All 4 jacking points are perfect.   Next I want to service the gearbox. Sometimes it's a little reluctant to shift up and I'm hoping a fluid change will sort it. I also have 4 new rear subframe bushes. They're as big as a toddler. I'm renting a tool to help put them in. I can't wait for this because its a bit crashy back there at the moment.
    • Remember when those donkeys kept using freedom units and smashed that satellite to bits on the moon? NASA has their brain switched on and uses the metric system.
