  • Replies 91
the brakes will fit under std R32 GT-R wheels (16") and also under std S15 rims when fitted to an S15. Will not clear std R32 GTS-T rims, as offset is wrong.
disc diameter is 296mm, as per R32 GT-R (non VSpec II) specs.
also, kinda embarrassing, but -
i was supposed to send the Splitfire coilpacks to someone a while back. Only thing i remember of his username was MR then some numbers. I accidently cleared out my PM inbox back then and lost all messages and contact details, didn't realise it until a few days later but by then had forgotten the username. :uhh: Been sending messages randomly trying to figure out who it was, but have been unsuccessful. If you're the bloke, and you're reading this, and if by some chance you still want them, pls message me.
dude how much shit did you have for sale? the list is so small now...
do you have any other aftermarket bits? catchcan still? strut braces or master cyl brace?
what springrate/damper adjustability are the coilys
cheers, adz
hehe i had like 21 items i think...
had all those things u mentioned, but have been sold - only what's listed is left.
JIC FLT A-2 coilovers are 8kg/m front 6kg/m rear (or was it mm? lol cannot remember the correct unit) and have 16 levels of damping adjustment, and is height adjustable as well of course. top of the line drift suspension :)
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
