At the moment wanting to buy a 32 for my first car, but theres this thought thats always pushing to the back of my head.... THE PETROL... and when your pumpin turbo through 6 cylinders; tends to drink a bit. But then i remebered some article that was on a current affairs or today tonight or somethin, about some way that you can make your own petrol out of the left over oil that fish and chip deep fryers??? apprently its really healthy.... but i don't know how true that is.. but this thing on TV was aggggggggggesssssss ago. does anybody know anything about this process???
https://www.sau.com.au/forums/topic/50205-homemade-petrol/
If your impending fuel bill is what's worrying you maybe you aren't prepared for the true cost of owning a Skyline? They are essentially a black hole for money, fuel bills, mods, detailing, servicing - then you'll want to upgrade to a GTR and AARRRGGGHHH!!!!
hehehe but its the best hobby you can have.
https://www.sau.com.au/forums/topic/50205-homemade-petrol/#findComment-998529
If your impending fuel bill is what's worrying you maybe you aren't prepared for the true cost of owning a Skyline? .....
nah its not that bad, i know the skylines gonna cost me more than your av car but hey ill find the money, actually the situation isn't that bad , just thought it was worth looking at cos free fuel would be pretty damn cool... guess it was too good to be true then..
https://www.sau.com.au/forums/topic/50205-homemade-petrol/#findComment-999550
funny that you say that, cause Optimax is supposed to be a shit fuel.
maybe you should stick to the home made stuff :rofl:
Hmm looks like we had a petrochemical expert here with his own lab and everything.
I wouldnt mind knowing the molecular makeup of optimax when you have some spare time
note: this post is very sarcastic.
https://www.sau.com.au/forums/topic/50205-homemade-petrol/#findComment-999571
whic is?....
One thing, RB engines dont run on diesel.
It is made by chemically reacting vegetable oils, animal fats with alcohol and recycled cooking grease/oil. Some bio-diesel is made from domestically produced soybean oil.
It can be made from both new and used vegie oil and animal fats. The fat is chemically reacted with an alcahol ( usually methanol ) to make whats called fatty acid methyl esters. Glycerol is made as a coproduct.
The oils and fats are filtered and preprocessed first to remove water and and contaminants. They are then mixed with the methanol and a catalyst ( sodium or potassium hydroxide ).
The molecules are are broken apart and then reformed into esters and glycerol which are seperated from each other and purified
I dont think you can run an engine straight of bio-diesel. It comes in blends.
B2 is (98% diesel and 2% bio-diesel)
B5 is (95% diesel and 5% bio-diesel)
there are also blends which have 20% bio-diesel (B20)
At the service station ( it still has a fair while before it fully spreads throughout australia ) it would cost around 1.5 times more than straight diesel.
It also has an energy content which is 10% lower than straight diesel. The more you add the less power, torque your engine produces.
Bio-diesel also reduces wear and a mild solvent will clean your fuel system.
https://www.sau.com.au/forums/topic/50205-homemade-petrol/#findComment-999573
I have an issue of "modern MOTOR (may 1974)" – the height of the fuel crisis - which has a formula for making your own petrol. It consists of a blend of :
Toluene (65%)
Benzol (25%)
Naptha (10%) - Heavy naptha, water-white)
Mix the ingredients (by volume) stir and poor in the tank through a strainer (you can get sediment from the naptha occasionally)
This mix is compatible with existing fuel and can be run on its own or in a blend.
This mix was tested on various cars of the day and "they all performed better and gave better economy .. than on either standard or premium octane petrol" - **I would be interested to know the octane rating of this mix, but I guess it must be in the mid nineties**
The article went on to say "we tested this petrol substitute in many vehicles without experiencing any trouble or damage to engine or any other vehicle components." but then went on to say "we accept no responsibility for any damage that might occur" (which makes sense to cover their own backs.
https://www.sau.com.au/forums/topic/50205-homemade-petrol/#findComment-999723
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
    • That's not very Toyota of the Toyota!
    • Bringing an old thread back to life Looking to put some new front shocks in the r33Gtst and the KYB still look ok for a road car. Unless there are any other options aroind that price $200 a shock?  I’d like to replace the strut tops also, is this the correct KYB no. For the strut top, KSM7124?  https://www.sparesbox.com.au/products/kyb-strut-top-mount-ksm7124?srsltid=AfmBOoq-HDru8wSlLnQrhU9gCw_uYdKg8gUQzONY-EQOdnI5iXOWEUjY 341287 appears to be the front KYB shocks part no.  thanks all
    • LandCruiser used to get a fluid flush every 12 to 18 months.   Only because it was about that often the electric motor on the master for brake assist kept dieing and needing to come off.
