This really should become part of the FAQ. The stuff you need to send to DOTARS has been covered in this and other threads, plus PHATR32 is given you some info.
But to summarise, you need to send:
- completed import application
- certified copy of drivers licence
- copy of purchase invoice
- proof of car age (usually Jap dereg doc)
These last two should have been provided to you via your broker or whoever your buying the car from.
  • Replies 250
If the first is a Monday, put it in the post on the Friday.
As others have said, read very carefully what you need to send in and make sure you fill out every part of the form. Screw it up and you will get large delays.
thanks guys
I have the application form
There is a JP in the building here at work, will get her to sign, a photocopy or my license?
I have the purchase invoice
still waiting on the dereg doco from jspec. called them about it today when I realised I didn't have it yet
cheers and thanks for all the help
mark
but if I send it express on friday it would arrive on the weekend wouldn't it? before the november date, unless the department isnt open
might do that then. put it in the post on friday arvo
cheers
mark
No. Mail is not delivered over the weekend (although it is transported apparently).
LW.
include a express envolope with your application addressed back to you... May speed it up aswell!!
i didnt do it but i should of... no news as yet aswell ppl they said if it doesnt arrive this week put a complaint form in and they will get it chased up! will be somthing like 8 weeks on monday!
A utter joke!
yayyyyyyyyy!!
I faxed my signed, black and white licence and all my documents on the 1st of Sept.
Just received import approval in the mail :D
now lets just hope it gets on the boat at the end of the month :|
I have import approval envy :)
It's a great feeling once you've got it in your hand, hope yours is not too far away.
My car went on the boat last Saturday, should be here in a couple of weeks - or that was the plan, haven't heard otherwise. Just got to get the B/L now.
2 months+ :boohoo: (december build)
I just hope it arrives before I leave for Japan in january so I can organise all the shipping etc before I leave.
Richard
me too richard, import approval envy
mines a November build. its creeping up slowly now, and I finally have all the paperwork ready to go. just a month wait.
wish you guys the best of luck with everything going smoothly now
mark
Awesome! now I have build month envy :D You lucky devil, with luck on your side you may just be able to have your car ready for christmas :)
Richard
Broker has confirmed that my car is 'on the boat', should be here in 2 weeks :headspin:
OohArrGTR: So DOTARS is saying your approval has definately been sent ?? In that case they probably have and it becomes an AusPost issue, but I would (nicely) ask DOTARS to confirm in writing (e-mail at least) that it was sent and the date of approval. Also ask if they can send a duplicate as the original may have been lost in the mail (it happens).
    • Is there a way to adjust all of the pedals in an R32 GTS-T? they all sit even, but seem to be a little high for my liking.
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
