isn't it amazing the totally different times for applications being done at the same time. can you guys post what you applied for, which scheme (sevs, 15yo, race) and which car?
  • Replies 250
89 GTR under 15yr rule.
Faxed it through on morning of 01 Nov. Received today. 9 working days to process then postage. Well it's actually very nice that one facet of this process has been quite painless!
Now, if the car would only get itself onto a boat...
Mark
Duncan: they're pretty much all 15 year cars..
Its seems actually fairly consistent, anywhere from 10-20 days seems to be the average. Few seem to be way long, but they are very much the exception and I have a feeling something funny was happening with them (got lost, funny car, incorrect details provided, etc).. or maybe they go into further detail with every nth car?
i think it's worth giving them a call now and then to make sure they have received it (then u get a reference number). Just to make sure it hasn't gotten lost.
I called them and they told me that the copy of my ID hadn't come through the fax right and they sent me a fax about it a few days ago. It actually went to j-spec because i had nominated them as my agent - (nice of them to tell me about it!!! but oh well)
Oh another thing, when i spoke to dotars, i mentioned that the money had come out of my credit card, and they said that that doesn't necessarily mean your approval is in the mail. If there is a problem, they'll take the $$$ out regardless.
mine arrived today actually.. nearly 4 months exactly from initial payment to delivery in my driveway.. http://www.skylinesaustralia.com/forums/sh...d.php?p=1099298
Hmm, i wonder if yours Godzilla32 was the one on the same truck.. there was a grey r32 on the same car carrier that dropped off my car.. Never know, maybe he was on his way to VIC ? would make sense timing wise if he left today..
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
