This really should become part of the FAQ. The stuff you need to send to DOTARS has been covered in this and other threads, plus PHATR32 is given you some info.
But to summarise, you need to send:
- completed import application
- certified copy of drivers licence
- copy of purchase invoice
- proof of car age (usually Jap dereg doc)
These last two should have been provided to you via your broker or whoever your buying the car from.
  • Replies 250
If the first is a Monday, put it in the post on the Friday.
As others have said, read very carefully what you need to send in and make sure you fill out every part of the form. Screw it up and you will get large delays.
thanks guys
I have the application form
There is a JP in the building here at work, will get her to sign, a photocopy or my license?
I have the purchase invoice
still waiting on the dereg doco from jspec. called them about it today when I realised I didn't have it yet
cheers and thanks for all the help
mark
but if I send it express on friday it would arrive on the weekend wouldn't it? before the november date, unless the department isnt open
might do that then. put it in the post on friday arvo
cheers
mark
No. Mail is not delivered over the weekend (although it is transported apparently).
LW.
include a express envolope with your application addressed back to you... May speed it up aswell!!
i didnt do it but i should of... no news as yet aswell ppl they said if it doesnt arrive this week put a complaint form in and they will get it chased up! will be somthing like 8 weeks on monday!
A utter joke!
yayyyyyyyyy!!
I faxed my signed, black and white licence and all my documents on the 1st of Sept.
Just received import approval in the mail :D
now lets just hope it gets on the boat at the end of the month :|
I have import approval envy :)
It's a great feeling once you've got it in your hand, hope yours is not too far away.
My car went on the boat last Saturday, should be here in a couple of weeks - or that was the plan, haven't heard otherwise. Just got to get the B/L now.
2 months+ :boohoo: (december build)
I just hope it arrives before I leave for Japan in january so I can organise all the shipping etc before I leave.
Richard
me too richard, import approval envy
mines a November build. its creeping up slowly now, and I finally have all the paperwork ready to go. just a month wait.
wish you guys the best of luck with everything going smoothly now
mark
Awesome! now I have build month envy :D You lucky devil, with luck on your side you may just be able to have your car ready for christmas :)
Richard
Broker has confirmed that my car is 'on the boat', should be here in 2 weeks :headspin:
OohArrGTR: So DOTARS is saying your approval has definately been sent ?? In that case they probably have and it becomes an AusPost issue, but I would (nicely) ask DOTARS to confirm in writing (e-mail at least) that it was sent and the date of approval. Also ask if they can send a duplicate as the original may have been lost in the mail (it happens).
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
