hicas light comes automatically when cars power is on. it is four whell steering type thingy which aids you in corenering, obviously. the wheels don't infact turn into a corner, they actually create a negative camber effect, but don't ask me exactly how much.
It does tend to make the car a bit drifty at high speeds and always wants to re-correct itself through a drifty. Which leads me to my question..... what happens to the Hicas if we get the springs re-tensioned ie; lowered / stiffened will it still work? Or can we get the hicas disconnected??
mmmm..
https://www.sau.com.au/forums/topic/5028-hicas/#findComment-79042
Guys
I too have hit the HICAS blues i recently noticed after i replaced the clutch on my car that the HICAS light was coming on and i would also experience a slight knocking noise with some ****house steering problem. I read up on what u can call a manual on the car and it said to check the fluid on the power steering pump i noticed it was a bit low so im gona top it up today as when i checked it was late and wanted do it when there was proper light. ill let you know how i go and if anyone else knows any other sure fire solution other then removing the hicas altogether let me know , but when you come to think about it if all else fails why not hey ?
oh yeah !
I have done the Hicas test on a prior occasion it was O.K. then not that you can tell much by it?
https://www.sau.com.au/forums/topic/5028-hicas/#findComment-79895
    • Throwing my spoon to the soup here a bit.  When I installed a 044 back in 2012, along with the direct power mod, the car became very difficult to start. To a point I burned one starter motor as I was late for work and tried to get the thing going. With some tuning and careful use of gas pedal when cranking it became bearable. Trying to make this short as possible, but the 044 died after 2-3 years, after which I went with an AEM 320lph pump, which also died after about 4 years to my dismay. After that I went with a Nismo pump, and while trying diagnose an emissions problem, I noticed for the first time that my fuel pressure was 5bar/72psi on idle, and that removing the vacuum line did nothing. After monitoring the situation, and removing the direct power feed and going back to FPCM in attempts to remedy it, I noticed there was fuel in the pressure regulator vac line. Kept the FPCM, installed AEM external regu and the car became sooo much better in every way, including starting. And I had driven it like it was for 11 years.. Anyway, I agree these are likely two different problems, and the FP problem you just haven't noticed before. I do not know much about haltecs, but what first came to mind was the CAS, which probably is not there any more. So how is the wiring from haltec to gauge cluster? How is the battery voltage and alternator?
    • Your car was auto before? You have different diff ratio (auto vs manual i think? or n/a and turbo?)
    • +1 for getting a screen off alibaba, CarPlay/Android Auto is vastly better than whatever navigation cars had 10 years ago. I got an Android screen for my 2015 BMW, huge difference. Fully compatible with factory stuff including iDrive controls.
    • Yeah, my offer was more to show exactly how rough and ready the rig can be and still be useful. Youtube vids will definitely show cleaner setups. Same concept though.
    • I would guess the seal has gone down at the speedo drive and gearbox oil has crept up the drive cable sheath and fouled the speedo head.
