GTR's
R32 August 1989 to 1991 = 1430kg
R32 August 1993 to 1995 = 1480kg
R32 August 1993 to 1995 V-Spec = 1500kg
R32 February 1994 to 1995 V-Spec 2 = 1500kg
R33 January 1995 to 1996 = 1530kg
R33 January 1995 to 1996 V-Spec =1540kg
R33 January 1996 to 1997 = 1530kg
R33 January 1996 to 1997 V-Spec = 1540kg
R33 February 1997 to 1998 = 1530kg
R33 February 1997 to 1998 V-Spec = 1540kg
R34 January 1999 to 2000 = 1540kg
R34 January 1999 to 2000 V-Spec =1560kg
R34 January 1999 to 2000 V-Spec N1= 1550kg
R34 October 2000 to ? = 1540kg
R34 October 2000 to ? V-Spec 2 = 1560kg
R34 October 2000 to ? V-Spec 2 N1 = 1560kg
R34 May 2001 to ? M-Spec = 1580kg
Wow a range of 150kg!
  • Replies 53
if u get a 200 s15, try to get a GT spec. its got nice leather seats. mm.
the s15 is much newer and would be in better condition. the r32 is a nice car, but for a daily driver, a newer car is probably a better idea. unless you find a mint r32........
plus the s15 has a semi decent stereo.
Jake- i rekon the 32 looks better than the 33, and theyre simlar cars underneath. the r33 would be in better condition, but more expencive. i rekon get a good 32 and spend ur spare on a stereo. and any repairs needed.
a newer car (r33) would be better for a daily driver, as i just said. i tend to repeat myself sometimes.
Having owned an R32 GTR, R33 GTR and S15 Jap Spec, I hope to give some though into the debate. I actually owned the cars all at the same time and all were modifed.
If not for the fact, the 33 GTR has a huge amount of power (just under 600hp), I would have gone the S15.
Much nicer car inside due to the fact its so much newer. Thoughts are biased now to an R32 because you dont see many nice S15's around. I would not get an R32 again. They are simply way too old. No matter which year R32 you get, the design is already nearly 15 yrs old. If you get a modified one, things are going to break. And the cost ALWAYS start from minimum, $1,000.
Think of the possible potentials with the S15. By the way, from all my cars, I got the most looks in the S15! Attached is a nice example that can be easily duplicated. Good luck in your choice!
Again, its up to the individual. For example, I dont think too much of my R34. I prefer the 33 GTR but yet my friends all say they would prefer the 34.
But to point out again, the 32's are old. GTR or not. And anything you do to it, youre just trying to make it look newer and freshen up the look.
Btw, did someome mention wide body?
defendrb26-img600x450-1093745920dscf0635.jpgdefendrb26-img600x450-1093745935dscf0639.jpg
I love the Silvia S15 and GTRs. It's a tough call but I'm leaning more to the R32. The amount of money I will have left to spare after compliancing and importing to do whatever is needed should be sufficient.
I would buy an R33 but the cheapest I'd get one is about $35k. I could probably swing that much but I feel it's important to set a budget and stick to it.
With $30k, if I got the S15 I wouldn't have enough left for anything really if something happened. I'd be lucky if I could afford the immobiliser/alarm/GPS/whatever I wanna put in. This is the same dillemma I'd face even if I could get an R33. I could shop locally of course for a car that has all this but it would defeat the purpose of an import.
The money saved on a GTR can be spent to breathe so much new life to it that it could be just as good as a new car, or near enough I figure.
There's also the fact that even if I got a Silvia, I'd still be wanting a GTR. Whoever said that is right :)
I have driven both a modified S15 Rspec GT and a modified GTR off their tits.
They are both outstanding cars. But for the price your paying to buy an S15 you will find a GTR in the same condition, so age/condition is not an issue here.
It depends if you want to go for modern european looks/interior on a powerful rwd sports car or blistering quick giddiness underneath an absolute m*ther****ing weapon.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
