In general, no it won't work. The stacker needs to be the same brand & vintage to work, although Sony & Kenwood used to be compatible years ago... If the plug is the same it's worth a try, but don't buy anything without seeing it work.
You'll just have to budget for a new stacker too. Damn!
Z
https://www.sau.com.au/forums/topic/50283-6-stackers/#findComment-1000625
personally, im not a fan of stackers n would stick with the panasonics with the mp3 playback...my mate just got one and its sooo nice. worth $1100 n he got it for $300!! i wish i couldve got one :)
my pioneer mp3 is good enough though.
if it dont work n u still want a stacker...go for a 10 instead of 6
https://www.sau.com.au/forums/topic/50283-6-stackers/#findComment-1000659
i has heard that if u get a stcker and an mp3 h/u...the h/u decodes the mp3 and u still have a stacker...please correct me if i am wrong
i got confused when i saw that coz ive seen mp3 stackers, unless that is for a normal h/u, but then i figured it wouldnt have the folder menu's n stuff...
GO MP3!!
https://www.sau.com.au/forums/topic/50283-6-stackers/#findComment-1003495
    • Hey good to see you on the forums! Haha Considering this cars past with electronic issues I am leaning towards it being a wiring fault somewhere in the engine bay. When testing the ac relay in the fuse box there was no earth trigger. I am probably going to try "bench test" the compressor by giving it direct ground and power to see if i can hear the ac clutch click otherwise I will be pretty sure I have a dead compressor. If it does work then I will be tracing some wiring it seems.
    • Haha, the big brain move is to buy a second set of headlights to clean up or retrofit. I definitely don't have one sitting in a cupboard that hasn't been touched since it arrived. Just have to ignore the intrusive thoughts that suggest the second set is not quite as good as it could be and to buy a third set that the job would definitely get done with
    • Nah I'm talking about the GTS-t with 15" wheels and single piston brakes.  I've seen them pop up occasionally over the years. You can see it in the brochures. Most were early models (aka Series 1).
    • Oh man... I've been here, that's for sure. I love my ugly but still functional headlights that can never come apart again.
