I've got this strange problem with my indicator. It won't stop ticking after i use it or when it gets back to the centre. The lights switches off but the ticking noise won't go away or slowly slows down but won't completely stop. This happens both after signalling left and right, and after switching off the hazard light.
Anyone ever had this problem before or knows wats going on here? Please help.
oh its an r33 gts.
Thanx in advance.
https://www.sau.com.au/forums/topic/50296-indicator-problem/
Have had the same problem (intermittent) for 2 yrs now.
Can be very annoying when it happens and often seems to do it just to piss you off. Mine is occasionally accompanied by a wisp of smoke from the steering column, like a component or some PCB track is getting cooked. It surprises me that the indicators still work.
In short, I cannot really give you any clues but, I will watch this thread closely. And you are not alone.
El Bee
the alarms all good, but can u explain more about the relay and the flasher unit how i can get to these and test it etc...
Cheers
my guess is the switch itself , they play up just like the headlights .
take it out and have a look at the contacts .
El Bee
no sh*t i just had my first wisp of smoke coming from the exact same place this morning while playing around with both the indicators and the hazard light, scares the living daylite out of me lol.
Any other ideas people, and how much does the switch costs to replace?
thanx
OMG... this had been happening with me for a while now too. On Sat i took part of my dash out, found the unit that makes the ticking sound - soz i didnt take pictures, the camera was flat.
The unit looked to be in good order, and i thought i'd leave it disconnected to stop the sound.. heh.. but that makes the indicators not work At All! Not even the hazards.
I have had the soke from the steering column as well.. a ripped off the tiller housing but, couldnt see any wires that looked shorted, all wrapped up in black tape..
I suspect it might be with dodgy wiring of the turbo timer (i have an apexi pen type TT) or immobiliser unit... I too would like any recommendations on how to fix this issue... i really dont want to take it to an auto elec who has no idea about imports with turbo timers and stuff.
azron i know which unit you disconnected cause i did the same thing yesterday and the whole thing didn't work. Its the rectangular cube thing next to the cyclinder tube unit, it was 3 flat plug (not really good at explaining this) connection thing, it think is got a english tag label that says something like "MILES" and other stuff.
Just out of interest wat engine oil do u guys use, i've got the castrol magnatec 10W/40.
ta.
ok guys found out wat the problem is, its the indicator switch itself which is in the steering column (where the smoke came from), not the flasher relay cause thats under the dash ontop of your left foot.
Only problem is to find the replacement switch. Might try wreckers or somethin, or ni$$an if its not too expensive.
:D
    • That's the thing....the basics of fuel and ignition are deceptively simple.....getting it to behave like factory in all conditions after airflow mods is way more complex. Newer cars like the V37 are all about modifying the standard ECU which is about a billion times more complex than they were 20 years ago, with a bunch of parameters affecting others
    • The larger TB I had on the SS was a pain to get to idle right, but, that was cable In the end they just raised the idle up a couple of hundred RPM so it was happy idling away either in gear or in park (slush box life) I'm curious on how my NC will idle with the new intake, larger TB, and cams that are currently going in/on, but I have faith that MX5 Mania will sort this "electronical" "black magic" out the best they can in the tune with a electronic TB Sometimes I wish I knew more about the intricacies of tuning, but most of the time I don't because I know it would hurt my brain 馃ぃ
    • That's the thing. Cam is smaller than before.. though the old cam was +6 degrees advanced. We're talking huge changes here, the narrowbands want to trim out 20% of fuel and pull the (wideband) idle to like 16.0 AFR or such. One side is a little more trimmy than the other. Think along the lines of ~20% to ~15-18%. Unfortunately my scouring of the internet hasn't really found anyone with this issue. People either just disable NB's or have them wildly different, where one is -20% and the other is +20 or 0 (i.e a sensor is just dead/wiring is just busted). Turning them off and relying on the base map only results in the wideband reporting at about 14.0 with the Varex closed. It'd be a little leaner (closer to 14.7ish) with the Varex open. I know I can just change the switch points so that the narrowbands agree with the wideband, but it's still odd. Both of them are reading voltage, it's just that they're reading quite high mv, in the ~800 region. It's just odd. This was with the IAT fudged to report it was about ~22 degrees which is my guesstimation of the temperature in the room. I have an OEM sensor ready to try tonight, which is slow and crap - but .. worked last time I used it. Sadly I am aware that idle tuning with the big TB is going to be a PITA and I look 'forward' to many hours spent stalling or stumbling idle or delving into drivability things.
    • The GTR strut brace clears the new manifold.. by about 0.5mm. So this means I need to buy an OEM GTT Strut brace (again), which will clear the new manifold, but not the bonnet vents. I guess I can sell the GTR Strut brace with the bonnet with the vents as a package deal as someone will need this one day. So my choices are vented bonnet but no strut brace, or GTR Bonnet with OEM brace (which I have to buy) but is bright red instead of the same colour as the rest of the car, which means the entire front end of the car will just be red until it goes back to paint jail. In other news the engine starts and doesn't leak. Why both O2 narrowband sensors think the tune is rich AF I do not know. The idle is also pretty shitty and my expensive IAT sensor from the USA is dead. The car sounds awful. But I assume or at least hope this is due to the many exhaust leaks, and the concrete garage it is in, sitting there with 0 intake bolted to it, and no bonnet or panels or anything to stop the induction/intake sound which is about 200db.
