Ok guys i have completely pulled my dash aprt to try and install two autometer gauges i have bought. They are water temperature and oil pressure. I have ran the power cables and two appropriate hoses, one for each gauge, into the engine bay, my only problem is i have no idea where they go. So my question is where does the plug for the water temp gauge go and where does the hose for the oil pressure go?. My car will be off road until i get them in as puttin dash back together to drive it then pull apart again is somethin i cant be stuffed doin so any help would be greatly appreciated!. This is on a r32 rb20det. Thanks guys.
https://www.sau.com.au/forums/topic/50307-gauges-need-help-asap/
For the oil pressure you have to find the oil pressure sender on the side of the block where the oil filter is. I'm trying to put my oil pressure on at the moment, its a real prick because you have to remove the sender and then plug in a metal t piece and then put the sender back into the t piece. Btw the sender is directly left of the oil filter with a cable comming off it and a rubber seal around it. Some how you have to unscrew it which is very hard. I havent got mine off yet so any help from anyone who has done it would be great. Also with oil temp what did you guys plug yours into? My fitting is too narrow to fit inside the sump and seal it off, any reccomendations?
For autometer oil temp i drilled a hole into the sump and welded a threaded fitting to it. Screwed temp sender into fitting.  To do this means you have to remove sump, obviously.
Theres gott abe a easier way than that isent there?? As i an new apexi oil temp gauge coming soon with some other parts
    • Is rebuilding it even a thing? Where would the shop find parts for it? I looked at some off these local online stores for my r34 and suprisingly they had brand new aftetmarket ones for $600-800 I think. I guess r32 might be a bit tougher.
    • I remember the days when E85 was priced in according to the $ per km outcome. Sure E85 was about 35% cheaper, but you also lost about 35% range... now it's fked..
    • They do. The pale yellow translucent ones from Japan were .... I dunno. Useless? Whiteline and SuperPro are probably fairly similar. There's bound to be a range of different hardnesses amongst the dozens of options on the market. The simple fact is that the pineapples don't get up inside the bush at all. They just sort of exist in the space between the washer/bracket and the subframe's bush outer tube, and...exert a bit of force between them? Or something like that. I'm sure that with enough provocation, they will simply allow one to move wrt the other.
    • I'm not sure they came in different hardnesses? Going from memory only - I had set them up in the balanced setup. I also have poly bushes, so I have both poly bushes and pineapples. This is what my memory tells me at least. I'll have to take a look under there to be sure. The tramp was so bad that I managed to eject/kill a diff bushing, so those I know are stock. The tramp is bad enough that you are 200% sure you are doing severe damage to the car. It's not just chirping or vibration, it feels like you're hitting a speed hump/kerb 10 times a second. The issue has persisted between subframes! (I went from Hicas to non hicas subframe and replaced every bush a few years ago now) so I'm entirely lost. Every arm is factory.
    • Can recommend the Frenchys kit, been using it 2 years now with no issue, very happy with it.  Only thing for me was upgrading the thermo fan but I am super fussy on cooling.   Also interested in electric AC, partly for boot mount to have a clean bay and partly would love the idea of cooling off the car before i get in. The battery setup to do that might be tricky / expensive though.  Found this an interesting watch.
