Ok guys i have completely pulled my dash aprt to try and install two autometer gauges i have bought. They are water temperature and oil pressure. I have ran the power cables and two appropriate hoses, one for each gauge, into the engine bay, my only problem is i have no idea where they go. So my question is where does the plug for the water temp gauge go and where does the hose for the oil pressure go?. My car will be off road until i get them in as puttin dash back together to drive it then pull apart again is somethin i cant be stuffed doin so any help would be greatly appreciated!. This is on a r32 rb20det. Thanks guys.
https://www.sau.com.au/forums/topic/50307-gauges-need-help-asap/
For the oil pressure you have to find the oil pressure sender on the side of the block where the oil filter is. I'm trying to put my oil pressure on at the moment, its a real prick because you have to remove the sender and then plug in a metal t piece and then put the sender back into the t piece. Btw the sender is directly left of the oil filter with a cable comming off it and a rubber seal around it. Some how you have to unscrew it which is very hard. I havent got mine off yet so any help from anyone who has done it would be great. Also with oil temp what did you guys plug yours into? My fitting is too narrow to fit inside the sump and seal it off, any reccomendations?
For autometer oil temp i drilled a hole into the sump and welded a threaded fitting to it. Screwed temp sender into fitting.  To do this means you have to remove sump, obviously.
Theres gott abe a easier way than that isent there?? As i an new apexi oil temp gauge coming soon with some other parts
    • Can't you put the pistons to TDC and then do the valve seals? Or will the drop down too far to pull them back up?
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
    • You have no idea how many goddamn boxes I received these past three months haha Most have been put to use by now though, luckily
    • Not going to pretend I didn't do a bit of junky work this time around, but mostly due to the fact that some things I am not willing to spend days fixing right now, like wiring. I try to do most things properly the first time around.
