Hey dynamix, you'll need to clarify this further but i'm pretty sure you'll be able to use the standard RB25DET one because the main differences aren't going to be with the motor, they'll be to do with traction control etc. There shouldn't be a real lot of difference with the two motors and tuning of them so the standard power FC should run on that motor. Also if you're runing the standard loom then the standard PFC will plug straight in.
i'd say youd need an r34 power fc, but thats just my opinion. the neo6 has different timinig or something added over than standard rb25det which says to me u need a specific r34 powerfc, otherwise you could simply use an r33 stock ecu, which woudn't work im assuming, ask your local performance shop or ask who ever did the engine swap if you can contact them
its about the wiring loom actually.
I'd assume when they transplanted the engine, then also did the wiring loom to match it, unless the Neo6 has the same wiring as a R33 motor.
Be careful dude.
If you have a R34 ECU, then a PowerFC for a R34.
If you have a R33 ECU (which I don't think would work with a Neo6 cause they are slightly different) then get a R33 power FC.
afaik, the Neo engine has continuously variable valve timing, whereas the the R33 engine just has stepped adjustment. That would mean the R34 PFC would be the only way to go as the R33 PFC wouldn't know how to handle it.
You'd better check it up with a tuner though - I wouldn't want you to go and buy something based on what I said.
i've got the ROM reprogrammer for the NEC controller chip in the power FC. If you've already got a power FC I might be able to reflash it to the right one (will need to borrow a neo one too to get the dump of the software), and it should work, providing the ECU pinouts are still the same, and the only diff between the NEO PFC and the non NEO PFC is just the software on the PFC.
Or you could just buy a neo PFC and sell your current one :D
    • As an ex-skyline owner Going off how these things are now "modern classics", I would keep the twins and just "refresh" bits that are required for reliable power and have a car you can take out for a cruise whenever you get the itch As a idiot who cannot leave things alone Going deep into the "rabbit hole" is a easy thing to do, as previously mentioned, once you start it becomes a slippery slope, wirh lots of supporting mods, and possibly rebuilds, and unless you have a bottomless pit of funds, the car can spend most of its life sitting in the garage,  broken, waiting for parts, or building more funds For a classic like a R32 GTR Basically, a reliable OEM+ refresh, that isn't a broken garage queen, is alot better than a car that you build, then break, then fix, then break again And it isn't just the engine you need to worry about, these beasties are getting on in age, and all parts are getting, and have got, expensive, the days of picking up cheap replacement engines and other driveline parts are well and truly over The funds not spent on going a single with quality parts, and with all the other other bits required to make it happen, could be spent on refreshing alot of other parts A wise man once said "If you cannot afford 2 GTR's, you cannot afford 1", I also believe he said this about 20 years ago when you could pick up a clean R32 GTR up for around $20k My advice for a R32 GTR (the one and only true Godzilla in my mind) is to think holistically about the whole car, the body, the power train, the suspension, the brakes, and the driveline SAU is a wealth of knowledge with decades of Skyline experience,  from stock, to OEM+, to modified to varying degrees, to full on or weekend or dedicated racecars, as well as full on money pits that rarely leave their garage Treat the old girl nice and give her what she deserves, you are a lucky man to own such a classic car
    • For that price you could buy the hypergear turbo (big fan as I run one) and the Haltech ECU..
    • +1 for the Elite 2500. Get some new knock sensors while you are at it (pretty cheap), look up the TAARKS Nissan knock sensor kit. You may also want to get new coils (R35gtr) while your at it (assuming your on stock ones), as they are a liability. Mine started right up and idled fine on the base map. Also go MAP over MAF, as said above, Haltech make this super simple right out the box. Another fanboy of DBW here, Outsider Garage from your neck of the woods make some nice conversion gear for the R33 (that’s where I got some of my gear from).
    • Nvm ignore this I read it wrong
