Fluttering has everything to do with your BOV working or not. The sound is the air going back through your turbo. If you put a flat piece of tin under your BOV to block it off you will get the noise when off throttle at boost. If you adjust any BOV spring tension to tighter you'll get this sound because the BOV isn't opening at that boost level. Just means that air's going back into your turbo, not a good thing if you're running raised boost and want your turbo to last. You're better off with a pshh sound instead of the flutter.
https://www.sau.com.au/forums/topic/50334-flutter-sound/#findComment-1000467
Anyone heard of wastegate chatter?????????????????????????????????????????????
Can one of the experts here explain why my Bro's old 31 with RB20 and no BOV had this "flutter"
Actually, don't bother cause I thinks it's been covered a thooooouuuuusand times before!
https://www.sau.com.au/forums/topic/50334-flutter-sound/#findComment-1000526
The HKS makes the POD filter flutter at low RPM's and at high RPM will Make a high picthed noise and then Flutter. Tightening it all the way will not make it just flutter.
Tightening the spring tension in your BOV 'will' produce this flutter, even more so at high boost because the BOV will be inactive if the spring is too tight and the air will resonate back in the turbo instead of being released. Any car without a BOV will give the same flutter sound as one that's got their spring too tight, eg: boosted VL's that didn't come out with BOV's.
As i've already said, if you want the sound just blank off your BOV or tighten the spring in it, but don't expect it to last a life time if it's been boosted.
https://www.sau.com.au/forums/topic/50334-flutter-sound/#findComment-1000593
ill say it again... for all those that CBF.
The flutter is caused by the air going back through the turbo.
This is due to:
1) NO BOV
2) A tightly sprung BOV, that at low PSI wont vent
3) A stuffed BOV.
4) Some ATMO BOV's do try to make the flutter, but they dont really.
The dependancy of how long/pitch etc:
1) The type of I/C
2) The size of the piping
3) The size of the turbo
- ash
https://www.sau.com.au/forums/topic/50334-flutter-sound/#findComment-1000609
    • ADHD in all form isn't about "can focus, or can't focus" or is hyper active or isn't etc.   It's all a dysregulation. Either time feels to be stationary, or time just vanishes in a split second. We are either under focussed on the task at hand (as we're over focussed on our surroundings) or we have no idea an atomic bomb went off beside us as we're so hyper focussed and locked in on things.   Not to mention the rapid fire thought process. What it takes a "normal" process to think up a solution to a problem, ADHD will be able to give you 5 different ways to solve the problem, and the pros and cons of each. While we can be highly impulsive and lack the ability to "control ourselves" we can also become paralysed with the inability to make a decision for ourselves. While most of us have an OCD like requirement for perfection, we lack the ability often to remain focussed to get things to a perfect state. Those with undiagnosed ADHD as adults, can often find the last part actually stops them ever attempting to do things that they have the ability to do, as the reasoning is often "if I can't do it perfectly, it's not worth doing"   As for projects... Ha ha ha, I still need to take the other half of my wall trim down in the Fiance's office so I can paint it. Need to finish digging and running the back yard drains, my R33, getting the Ninja bike registered (now being sold), the moped project, fixing either of the lawn mowers so they're reliable, along with a myriad of other things.   It's why I've been going through lately and just being brutal and clearing projects off that I won't actually ever complete. IE, moped will go to the tip, or be given away, bike is being sold, Subaru project being sold, some parts for other projects given away. Or I've been making myself focus on one thing at a time, by ticking off the smallest quickest ones first.   There's also a reason by our mid twenties we seem to be "know it alls", as we've all been down some of the weirdest and oddest rabbit holes when you follow the dopamine trail. It's often also why we're more a jack of all trades, but not a master of one.   However, pretty much all of my hobby projects, in one way or another, all come back around to automotive. That's my zen area.
    • Remember reading about this not too long ago. been for sale for a long time  this is like when the wife says you need to sell the car so you put it up for a ridiculous price no one will pay
    • You are perhaps suggesting that it is not a super car? Well....it's not an AU.
    • Dropped the MX5 of this morning to get the hardtop colour matched and some PDR done, they are also going to give it a buff to remove some "stubborn" swirl marks and light scratches in the clear coat Over the last few months the poor little thing has copped some shopping centre car park abuse, I try to not park in them, but hitting Westfield's a few times over the last few months has taken its toll, nothing really bad, but enough of a trigger for a "while we're in there" thingie  Once it's back and all the one colour, with a few dents and mark's removed I'll give some of these products a go and see what they're like
