  • 4 weeks later...
a mate of mine was pulled over and they said you cant drive a 33 on Ps. He didnt believe them so he called the cop station, or Vic Roads, or someone, and they said that its only the GTR that Ps cant drive. They removed his fine or warning or whatever, and never heard anything of it again.
i know that the tightness level of cops depends on the areas and their knowledge of the cars around them... but aybee.. thats really interesting, maybe the power/weight restrictions have changed since i last checked, or maybe vicroads have made a mistake somewhere?
Since R33 are imports, VicRoads may not have factory spec data for it, thus they may only refer to R32 GTR which were Australian delivered, with factory spec 206kw. Thus the power restriciton on GTR, but since R32/33/34 GTS-t were not officially imported by Nissan, they may not have that data and therefore those cars were not in their list. However doing the proper calculation based on factory spec, if all skylines were australian delivered then GTS-t could be included in the list (except perhaps R32 GTS-t, as the RB20DET factory spec has less power than RB25DET)
that could be possible but it seems unlikely that the cops wouldnt be into this by now.
What im trying to understand is why they use power figures from the factory (at the flywheel) and not at the wheels? I understand that getting these kind of figures would be a problem but it seems like an inaccurate measure of the cars true power
you're thinking is right, power figure at the wheels is not as accurate as factory spec claim (although we know that Nissan may have 'detune' factory spec claim on GTR to make it look like didn't exceed 206kw gentlemen's agreement).
There's so many factor on dyno that can affect power at wheels, tyre size, ambient temp, worn clutches, etc. Each car even from the same make and model can show different figure on dyno, especially 2nd hand ones, and testing each car out there for every P-plater would be uneconomical, so just use the factory spec figure and calculate from there what is allowed/not allowed.
If you keep getting pulled over my advice to you is log it (write it all down) and make a complaint. I"m not sure who does police complaints in victoria.
I remember one of my friends bought a car from a drug dealer - he used to get pulled over by d's, undercover, highway, local - every cop car. After he found out who the car belonged to and complained to his dad (some richy rich conections guy) who made a complaint to the police and ombudsman (or whoever) and he never got pulled over again.
  • 3 weeks later...
    • I much prefer that to an actual oil pressure issue, never would of thought it would of been a volt drop issue but SAU brains win again. Guess ill be turning down the oil pressure limit for the track and hunting some grounds. Ill hopefully update this thread with some high oil pressure and solid ecu voltage logs.
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
