HKS GT-SS's installed!
600hp
 Share
At least a bleed valve would hold boost steady :P
I'm using a Turbosmart eBoost, in case anyone can offer any solutions or suggestions...
you could give your actuator rods a few mm more preload it will help hold higher boost levels... thats what i needed to do to hold 30psi steady, my base boost is now 14 psi with zero setting on my id3 blitz controller...
well done with those power levels so far...
hope this helps....cheers...
....More than enough for track work IMHO.
Now it's time to attack the car with weight reduction :P
:werd: ... As long as you are still making good power up top, i seriously doubt even guys with 400+rwkws will be able to match you coming out of a corner and have enough of a straight to catch and overtake between corners. ;)
Yeh now you need to rip off the HICAS, throw in some Kevlar seats and goa rac'n :headspin:
great results merli thats what we expect as well.
when does the boost start,and could you post a copy of your dyno graph,as i think everyone would like to cheack it out. how many kays did you put on it before the tune and who was it that did the tune if you don't mind?
dough boy do you think it could be the exhaust housing that could be causing the boost struggle.
another thing was that on the HKS web site they state that the SS's are ment to flow as much as the 2530,320hp each i think.
i don't know how true that maybe ,but i've also seen a HKS dyno graph the a set of SS's on a 2.8L and 274deg camed car pull 750HP at the engine!
has anyone SEEN! big figures from GTSS's.
Merli again great result
by the was we are using a blitz i-D boost controller if that means anything,seems good but it hasn't seen any boost yet so hard to tell.
merli, i had a turbo smart e-boost put on my gtr last week and its working really well, turbo's are spooling faster as its helps hold the wastegates shut for longer. make sure your gate pressures are set right, they tend to spike and fluctuate a bit if set to sensitive and make sure your over boost shut down is set atleast .2 bar over your max setting... see how that goes
I bought ours of Dough boy but i'm not sure if he will get anything more from japan otherwise i would have got them of nengun!
the kit comes with 2xturbos 1xexhaust gasket and the little hoses that you need and it shows how to install them as well.
i was just at supernats and saw joe but his RX-7 into the wall not a pretty site but he's OK.
his car is stuffed.
I just heard through the grape vine that merli/andrews R33 GTR which just made 300awkw just died at the race track, i heard that it threw a main bearing. or something i hope this isn't true as i couldn't think of a better drag, than a r33 gtr with the same turbos and the same cams.
Andrew can you tell us, what happened?
 Share
    • I find I am using the MX5 for everything except long overnight cruises with Jackie, or, if picking up the kids to go somewhere, the SS has so much more room inside, and is much more comfortable if your going to be doing Hwy driving for 6-8 hours And the MX5 isn't bad in stop go traffic for a manual transmission car, whilst the clutch kit has been upgraded from stock, it is still light, and also not having a stupidly light flywheel in it helps as well, I've spent alot of time sitting on the M5, M4 and M7 stuck in traffic when plodding around the Greater Sydney Region in it Another benefit is MX5's are not really a car that gets stolen, you can pretty much park it anywhere, and it will still be there when you return
    • I can totally get why you like it for that sort of commute. I was thinking BoganDore because it's such a lazy drive, for things like stop start traffic.   I used to do over an hour in stop start shit from one side of Bris to the next, twice a day. My choice of car was larger displacement, with an auto. Basically for torque in low rpm/very low speed, and no clutch pedal. But loved a fun manual for the weekends, which the partner has (plus had the LandCruiser too for other fun drives). I now have an EV as a work car, and I tell ya what, ultimate daily driver, especially if youre out of energy, like I often am after work. I don't even need to touch the brake pedal   That said, I'm presently rebuilding the Liberty GTB to get it setup for weekend drives and track abuse! So small high revving turbo engine with 6 speed cog swapper!   But for your style of commute, I'd probably take the MX5 too!   For those choices, I'm ignoring fuel economy. Because I know how atrocious V8 daily life is for fuel from when I used to daily a manual SS, ha ha. Hence why I know I love the daily rumble of a V8
    • II know what u are saying after 9 years of hibernating my stock engined  110,00km gtt I got it registered 2 weeks ago. Took it for a drive a couple of days ago and some fresh bp fuel, I just couldn’t stop grinning and dreaming of when I will start my build thread. its just such a primal man feeling many forget to enjoy I wish u so much enjoyment with your little racer mate
    • People just don't understand how good MX5's actually are and how fun they are to drive, park, manuever. You feel like you have got some fun cheat code, while everyone else is sitting in their luxobargeSUV like normies who missed the point of living. It really is that noticable. As long as you/your stuff fit, and you're comfortable (they are), a MX5 is the best car on earth to daily around.
    • Before and after, headlight's done along with bumper.
