ok hi there im from melbourne and i was looking into buying this boost controller
http://firesport.ipspace.com/?section=item...n=show&id=10382
im probarly gonna purchase it today i was wondering is this type of boost controller leagal in VIC or melb meaning i wont get done buy the epa...and aslo are they any good ?
https://www.sau.com.au/forums/topic/50359-boost-controler/
most boost controllers are illegal. any boost above factory boost setting modifies your emitions and therefore violates epa regulations. the best is an electronic solenoid, that turbo smart one is a bleed value, meaning it will always bleed and have a max limit of X psi whatever you set. an electronic solenoid will bleed once it reaches X psi (whatever you set). also the electronic solenoid will handle different conditiions better. the bleed value will spike in different weather etc, like if its a very cool day and its set to 8psi it may spike to 11psi whereas the electronic solenoid should stay at 8psi. of course this depends on the actuator fitted to the turbo, im assuming stock turbo here
if you want to look at an electronic controller check out a hks evc 3 or 4 or 5
i hope im correct with all that info :)
https://www.sau.com.au/forums/topic/50359-boost-controler/#findComment-1000677
thanks for the help that was very helpful..i think ill stick with electronic boost controllers ...thanks
https://www.sau.com.au/forums/topic/50359-boost-controler/#findComment-1000786
    • Is rebuilding it even a thing? Where would the shop find parts for it? I looked at some off these local online stores for my r34 and suprisingly they had brand new aftetmarket ones for $600-800 I think. I guess r32 might be a bit tougher.
    • I remember the days when E85 was priced in according to the $ per km outcome. Sure E85 was about 35% cheaper, but you also lost about 35% range... now it's fked..
    • They do. The pale yellow translucent ones from Japan were .... I dunno. Useless? Whiteline and SuperPro are probably fairly similar. There's bound to be a range of different hardnesses amongst the dozens of options on the market. The simple fact is that the pineapples don't get up inside the bush at all. They just sort of exist in the space between the washer/bracket and the subframe's bush outer tube, and...exert a bit of force between them? Or something like that. I'm sure that with enough provocation, they will simply allow one to move wrt the other.
    • I'm not sure they came in different hardnesses? Going from memory only - I had set them up in the balanced setup. I also have poly bushes, so I have both poly bushes and pineapples. This is what my memory tells me at least. I'll have to take a look under there to be sure. The tramp was so bad that I managed to eject/kill a diff bushing, so those I know are stock. The tramp is bad enough that you are 200% sure you are doing severe damage to the car. It's not just chirping or vibration, it feels like you're hitting a speed hump/kerb 10 times a second. The issue has persisted between subframes! (I went from Hicas to non hicas subframe and replaced every bush a few years ago now) so I'm entirely lost. Every arm is factory.
    • Can recommend the Frenchys kit, been using it 2 years now with no issue, very happy with it.  Only thing for me was upgrading the thermo fan but I am super fussy on cooling.   Also interested in electric AC, partly for boot mount to have a clean bay and partly would love the idea of cooling off the car before i get in. The battery setup to do that might be tricky / expensive though.  Found this an interesting watch.
