Hi all , been looking into this as a convienent way to get a modern affordable (?) turbo for RB's . It has an integral waste gate with I think GT35 84 trim turbine and possibly 82 or 1.06 housing . The compressor (GT40) trim I don't know but could be 50,52,56T , and uses a .50 AR compressor cover . Ford claims 240Kw and the aftermarket are I think up around 280-300 . For those who want an OEM appearing turbo capable of serious power it could be the answer . Can anyone tell me what the wheel trims are and the exhaust housing AR . I have a part no I'll post later which is either the unit or CHRA number .
Cheers A .
https://www.sau.com.au/forums/topic/50379-ford-ba-xr6-garrett-gt3540r/
discopotato03,
I have one it in my R33, but with a .82 exhuast housing (integral waste gate). You can buy from Garrett a GT3540 (Same spec. to the Ford GT3540), but the compressor cover is .70 not .50 like the Ford and it come with a 1.06 exhuast housing (integral waste gate). The only different b/w the Ford exhaust housing is that it have the word "Ford" printed on it whereas the other have "Garrett". It is rated 700hp and you can get one from Ford for about $3,500. If you shop around for the Garrett version (the Ford turbo is Made by Garrett anyway) anything around the $2,500 is a good price.
If you decided to go for is turbo then my advise is get the turbo supplier to quote you a price where they will custom fit a .82 exhuast housing (integral waste gate) instead of the 1.06 housing which come with the turbo, this would require machining of the housing to fit the bigger turbine wheel.
When I fitted this turbo in the car with the 1.06 Ex housing; there were so much lag!! It was making full boost (9psi) at about 4500 to 5000 rpm (this was bad and not what i wanted). So, out the turbo when and in when the .82 Ex housing instead (much better; its making 9psi at about 3900 rpm). With this turbo, i am making 210 KW at the wheel with 12.5 psi. Mod includes; 3" exhoust, FMIC, Power FC, fuel pump, air filter and everything else is standard. I hope the information helps you.
NisJet.
Thanks Nizjet . I'm looking for one for a RB26/30 with a bit more low down than that . Also the .50AR compressor cover would help to bring it on a bit earlier . Maybe I'm aiming too high and should be looking at a GT30R with the .82 AR exhaust housing .
Does anyone know which CHRA's go into RB25 Hi Flowed turbos . I think in the 33/30DET thread SK comented that one of them worked well . If FoMoJoke wants $3500 for their name on it they can go rip some F'n Orible Rusty Device pilot .
Thanks A .
    • Hey guys, Just thought it might be of interest to owners of the RB25 det NEO motor, that awesomeness Nitto are in the late process to produce an engine gasket kit by end of Jan 25.  I think obviously there will be an 25det kit too. cheers, Ian
    • He is around but doesn’t really do automotive stuff anymore, mainly does commercial work now
    • Shortly after I do the usual full exhaust/ fmic/fuel pump/ R33 turbo and still get flogged at the lights by i30Ns
    • Is Chris from Craved Coatings still around? He is an ex SAU guy and did great powder coating (back in the day at least)
    • Bumping this thread yet again, has anyone ever tried putting yet another vacuum regulating valve on the hose that goes between the turbo inlet? Something local owners have mentioned is the Radium breather pipes de-restrict the valve cover but it actually produces an undesirable outcome in practice, way too much air is sucked out of the crankcase and a ton of oil comes with it as well. As far as I can tell the PCV diaphragm in these modern euro wet sump performance engines is active during boost as well, there's just a check valve to block boost from entering the valve cover and crankcase as there's no inherent check valve function in these diaphragm-type valves. Hopefully I'll be able to try some of this out soon. The Volvo XC90 4.4 V8 has a nice external version of these things.
