Hi all,
Just wondering how people go about contacting or purchasing products from not so mainstream japanese tuning companies?? Garage F ukui SPL, i have a non genuine fiberglass kit meant for a 33 and what i would like is the genuin plastic kit but cant seem to track down a wesite or contact details for this shop.
Nehelp or suggestions would be much appreciated.
Cheers
John
https://www.sau.com.au/forums/topic/50429-garage-ui-spl/
Cheers mate, will do. I found the same thing everytime i searched it came up with something to do with mr2's. I know for sure the kit i have is garage ***ui as it was originally moulded from the garage ***ui plastic kit off a car that i now think has been stolen and i cant find ne details on.
https://www.sau.com.au/forums/topic/50429-garage-ui-spl/#findComment-1001642
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
    • That's not very Toyota of the Toyota!
    • Bringing an old thread back to life Looking to put some new front shocks in the r33Gtst and the KYB still look ok for a road car. Unless there are any other options aroind that price $200 a shock?  I’d like to replace the strut tops also, is this the correct KYB no. For the strut top, KSM7124?  https://www.sparesbox.com.au/products/kyb-strut-top-mount-ksm7124?srsltid=AfmBOoq-HDru8wSlLnQrhU9gCw_uYdKg8gUQzONY-EQOdnI5iXOWEUjY 341287 appears to be the front KYB shocks part no.  thanks all
    • LandCruiser used to get a fluid flush every 12 to 18 months.   Only because it was about that often the electric motor on the master for brake assist kept dieing and needing to come off.
