advertising this one for a friend who is leaving the country very soon.
Yr/Make/Model
1999 Mirage
Engine hardware
6A12 Mivec
Engine accessories
Haltech E6K ECU, NGK racing plugs, RPW 6-2-1 extractors, K&N pod filter with CAI piping, High flow cat, 2.5" press bent exhaust from the extractor flange back. No resonators, one muffler. Two Davies Craig slimline thermo fans.
Drivetrain
Brass button clutch, FTO 5speed, diff, flywheel and driveshaft.
Brakes and suspension
Standard front discs with EBC green stuff pads. CK Lancer rear discs with EBC black stuff pads. Koni special adjustable shocks, Lovell lowering springs. Camber kit.
Rolling Stock
Momo Ferrari Engineering 16s. Pirelli PZnero rubber on front and P7000s on the back. 45 profile and 205 width. They've done about 5000kms so they're basically brand new! These tyres are worth close to $400 each...
Bodywork
deleted antenna, customised kit, PIAA spots, semi reflective tints, custom moulded GT4 bonnet scoop, aero mirrors
Interior
Sparco Torino seats, Momo tiller, Momo shifter, Momo gear boot, Sparco pedals, partially retrimmed door skins, electric windows, show install in boot.
Stereo
Panasonic DF800W CD/MP3 player, Infinity splits with MB Quart tweeters, running on a brand new Alpine 2x50wrms amp. Infinity Kappa Perfect 10" subs x2 running on a Response 4x100wrms amp. Sounds very loud and very crisp!
Its pretty quick, handles well and stops really well. A tad front heavy as you'd expect, but that was easily compensated for with a fat rear sway bar and a front strut brace (not coming with the car) It sounds mean and burbly due to the exhaust.
$15500 ONO
Any questions at all please call 0419 007 180 he is leaving the country very soon
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
    • What HVAC actuator is under the steering wheel? Do you mean on the RHS of the centre console, immediately to the left of your shin? If so, then yes, it is probably that one, because that is the mode door actuator, and from what I know, it's still a pain in the arse to replace. I don't know about whole dash out, but you certainly have to rip into the centre console section. I don't know if it's covered in the workshop manual, as I haven't spent much time looking at those parts of it. (and by "the workshop manual, I mean the R32 GTR one, which is the most comprehensive one we have, and it should be similar enough between that and later cars to serve as a guide).
