Need help with wheel offset please !!
Hi all,
i bought this set off rims and tyres for my 33Gtst but i assumed that it's more for a GTR than a gtst. ( If it's for GTR then GTR boys get your $$ ready if you want it :wassup: )
Its' VolkRacing Daytona JJ, front is 17/8 PCD 114.3 OF+45 5 H BMT
rear is 17.95 PCD 114.3 OF+40 5H BMT.
I could be wrong with the numbers as it was dark but otherwise everythings that i wrote here was right.
They VOLKRACING symbles are at the front but the sticker say RAYS ENGINEER at the inside so i assumed that RAY make them, if so then are they LIGHT WEIGHT? I went to Volk site but i couldn't find it, maybe its too OLD.
Another thing is Tyres are GrandPrix M7R, are they good?
https://www.sau.com.au/forums/topic/50456-need-help-with-wheel-offset-please/
OK it was 45 for front and 40 for rear, took a closer look today. The rear fitted perfectly, excepted for the FRONT. Touch just a tiny bit on the capliper ( DAMN ).
The R33 GTSt offset is +38. +45 sounds like a wrx offset. Do you know what car they came off?
It can never be for a Rex because it's 17/ 91/2 at the back and 17/ 81/2 at the front.
Anyway i'm taking it to THE TYRE FACTORY see what they can do. Properly they will put SPACER in it, you guy reckon? Is spacer legal in VIC?
I don't want to let go of this set cos' i like it. And yeah its' does feel LIGHT.
did you buy those rims off firesport?
No, i bought it of this guy David who owns a Mini Me of Nigel supra, it almost identical to Nigel's one but it's none turbo so i call it like that :headspin: .
And yeah the offset is 45 compare to standard skyline 38 so i don't understand why it touch the capliper a bit, maybe i should move it around and stuff.
I told nige about that supra when i first say it a few days after the autosalon earlier in the week and he was determined that it was not the same orange :P
With ur wheel spacers, it is illegal to have them floating they have to be bolted to the hub.
Be carefull with the tyre factory especially the dande one as they will tell you abything to sell you something.
Rays are the manufacturer. They make all different brands of rims eg. Nismo, Versus, Volk and Gram lights just to name a few. I've seen those rims before on a 33. Not sure of offset sorry. They would be at least 4 or so years old.
Might sound silly but have you just tried fitting them??
Yeap i have, it's the support behind the spokes ( the six spokes ) that touch my capliper, i need around 3 or 5mm. The rear sit perfectly its just the front that is :headspin: .
I got the whole set for a G, jus found out the tyres alone on them worth more that a G but it's not just that, i really like it therefore i've tried at a lot of places inclued one Engineer place to see what they can do but it seem like there are no lucks guy so it might have to go on the for sale section.
It seem like spacer is the last option that i have. Anyone here have/experience spacers please pm me or anyone know WHERE TO GET THEM.
Not happy Jane. :mad::(:mad:
The offset has nothing to do with the size of the rim. Where you are right is the fact that the PCD of your Volks would not fit a Subaru. Subaru generally have a PCD of 5x100 which I failed to pick up on... However, Lenso agree with me on the offset :mad:
    • The plan is to get it out of the shed. The reality may fall some way short. But hope is as cheap as despair as they say. Will go a wide band I think. The coils are ok so maybe I’ll miss the $1500 on the R35 coils etc. Im still on the fence about a trigger kit. The HKS one looks nice ($1k) - not sure how it works with the Link or if Link prefer something else. Oil pressure is fine so I’m not that concerned there. Fuel pressure I’ll have a think about. The IAT got changed for the Link anyway as the old RB26 ones were really slow reacting and pretty poor. The Power FC just worked. Wasn’t terribly refined but it just worked. Probably made a mistake replacing it really. E85 isn’t available locally - it is 100+ kms away which puts it in the too hard basket. Lastly I understand Tunecorp in Perth are pretty good so was probably going there.   As for turbos is there are new age -5 drop in replacement? Turbos have come a long way in 20 years, everyone is big single which is fair enough but I prefer the old school complication of twins. Wasn’t chasing more power (well, not much more) but more efficiency would be ok.
    • I thought I'd share this....the shell is non genuine but they found or built a lot of the genuine parts. Plus, it is by far the best colour scheme of those years, the winfield once was particularly shit https://www.v8sleuth.com.au/written-off-inaugural-godzilla-recreated/
    • Good work Pete and glad the car held up well....been a while since I've seen you try properly
    • Just quick update, I've had tech issues and so a backlog on life stuff....I will pull lap times from the video and data from the ECU logs to do a proper update. But basically, in order of importance: 1. The car was excellent fun on the track, really felt a lot like the good old days. And nice to have AC while waiting 2. Coolant got really hot; again I need to pull and analyse the logs but the standard system is not up to tracking at 30o+ days, once the system was heat soaked after the first 2x15min sessions I could only do 3 laps before it got 110+ and I had to cool down. If I can't improve that it is a deal breaker 3 Oil temps were fine all day, noting it was short sessions due to 2. I think it will likely need work 4 Biggest surprise AT temps were fine, never went over 100, I would have been OK with 120 before I was too concerned. The auto sucks compared to a manual (of course) but it is faster to launch and I just need to downshift it manually before hitting the throttle, then it was OK. When I post the vids you'll hear it telling me off (beeping) for trying to downshift too early (it needs about 3500 before it will downshift, depending on gear a little but we are mostly talking 3/2 and 4/3) 5 A052s were not great which hurt the lap times, but I will be constrained in what I can get in good tyres that fit the wheel wells. These were small for a heavy car at 235/45/18. In theory I can fit 9.5 on front and 10.5 rear (so not square) but I still need 670mm+ high tyres in good brands. 6 Standard shocks/springs/roll bar are too soft for track work (of course), but that was always on the list. And happily, no white on the mat, despite having a teenaged passenger, extinguisher mount was fine. Also, it was nice to have Wakefield Park back in action  . Because the car was so quiet it is eligible for Green Day, which I thought was a band but is apparently a series of cheaper practice days they run with a lower sound limit, that is a smart idea.
    • Great to hear you are bringing it out of the shed again. Unless you have specific issues I'd just add the wideband, get a good tune and enjoy it. Certainly no point changing coils etc if they are working. If would add fuel pressure and e85 sensor if you are doing a general update but not if it runs OK and you are just getting it back on track. The other thing is smaller, modern twins, -5 are OK for motorsport but pretty laggy and old tech for street use (of course, if performance is the priority a modern single with twin scroll manifold etc is the go but not cheap). The final thing worth considering is switching to an ethrottle if drivability is still an issue, it should make things a lot simpler and smoother
