Hey all,
I'm lookin for some front mount piping to DIY, I wanna do the pipes the right way around (ie, no cold air-over-the-hot-engine) deal, noone seems interested in doing a job like this for a decent non-exorbitant price...
Gonna be needing a few bends/silicon hose/silicon reducers, piping.....
Where can I get some of this stuff from ?
Is the standard piping 2.5" ?
Cheers guys,
-Kym.
https://www.sau.com.au/forums/topic/50466-looking-for-ic-piping/
  • Replies 42
i got my intercooler + piping for $1100ish landed which i thought was a pretty good deal. Then fitted it myself. Pipes do go over the top of the engine tho, where else are you gunna put em through?
$350 - $400 sounds awfully cheap, let us know how you go tho
Kim I did my piping myself ... wasn't too hard
I have a Hybrid 600x300 type thing. I used the standard piping down past the pod filter, and then the far side of the cooler (the cold side) turned back around behind the cooler to join up with the standard piping.
It worked well I think ... no extra lag noticed and was good enough to make nearly 250rwhp at SST on standard turbo.
I'm changing it soon though as I have a new turbo going on .. but for stock turbo the setup seemed to work well :cheers:
slightly off topic but still on intercooler piping. who can make up custom cooler piping? ie which workshop? Not for my car, I got FMIC already :rofl: but for my bro's GT4 Celica. Looking mild steel but stainless would also be considered. I heard Per4manz can do cool piping? anywhere else?
Update: Picked up my SS Mandrel Bends and bits of pipe from Allbend Engineering in Ossie Park, cost me $104 all up, now I just gotta pick up some silicon piping reducers, and some hose clamps and put it all together...
I've decided to go with the 180degree bend on one side of the cooler to retain the stock return/output pipes. I'm going to do a comparison between the "over-the-engine" and using stock pipes myself as noone has any hard facts.....
hey strick,
glad to hear buddy. i went to allbends on friday, and he said that they only had 2 1/2inch pipe, so using a hybrid 3inch cooler would require reducers.
i would love to know how you go with the install, maybe some pics :D if you want a hand to help, let me know i would love to as i want to do the same for myself.
maybe we can get cheaper reducers or clamps if we buy bulk. let me know :(
God Bless,
Nate
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
