well you guys are always whoring on my threads. :cheers: :jk:
KURSED: are u using this car as a drifter or as a 1/4 mile car?
Because if your expecting good times on this Tank of a car. be very shocked. :rant: .. at 1450kgs its not going to go anywhere very quick.
But i have been known to go around corners sidewayz very quick oH say at 80km/h. LOL
The mods depends on what u want to do with the car.
For drift: get a bleed valave and an oil cooler and fmic. Then bobs your uncle dirft machine setup. Oh and also u need coilovers and diff.
1/4. I guess same setup as any of the other threads will have one for a rb20.
See most guys from what i have known buy the ceffy more for a drift car than anything else. I know i did. Otherwise i would have got a rotor an done a 12 sec pass standard.
I have absolutely no idea why that skyline stuff started appearing mid thread--- very odd.
to clarify, the cef will be used for neither drifting or strip, it is purely a daily driver.
I want a bit more power out of it - mind you i was stoked with the power and acceleration when i got the car a few weeks back, then i got used to it and now I want more. I'm sure most of you know exactly how this feels.
ok so I am off to find a
- boost gauge
- bleed valve
- air pod
and I will be having a chat with someone about the remapping of the ECU once this is done....
I ran 14.5 psi in my RB20DET and it promptly shat itself, so don't run more than 12 or it will cost at least 350 for the turbo and 700 to have your head pulled off and checked!
Very expensive lesson. Get another turbo if you want to run more boost.
- boost gauge
- bleed valve
- air pod
And get some agg pipe going to the pod. It will allow it to suck in clean fresh COLD air. I did it on my and on a cold nite, bloody hell did I notice the difference.
13psi is fine... no more.... just make sure its tuned on a dyno so u know its DEFINATELY 13psi its running.
CAI box is always a good idea too and can be done quite cheaply using that clarke rubber heat resistant foam stuff.... doesnt look as pretty as those nice carbon boxes but does just as good a job.... dont need a top cause it creates a seal against the underside of ur bonnet.
    • Thanks Pac!   I will reach out to them!
    • Yes, but 2 things of the top of my head, 1. Legalities of nitrous on a street car. 2. No chop chop. I fully understand that there's much cheaper ways to make power, and whilst a wet 50 shot is fairly cheap to install, bottle fills are expensive, and bottles always need to be refilled, and nitrous also has its own inherent issues with reliability, and tuning, from my experience of others using nitrous, it doesn't take alot to lunch a engine real quick if something goes slightly wrong when spraying, if I wanted a big chunk of additional powers, a spooly boy would make alot more sense, disregarding the additional engineering, supporting mods and other logistical issues of sticking a spooly boy on a car that came naturally aspirated from factory  In the end I'm not racing for sheep stations, and I don't really care if people make more power, or are faster than me, or spend less, or more than me, the only thing the car needs to do is drive around and make me smile, which it is doing now Really, I just want a shiny new intake to look at when I'm cleaning the engine bay, and of course, some more induction doorts, and maybe even that 5kw for that elusive 200hp cherry on top that I might get If the FAB9 intake plenum, TB and air filter box thing doesn't eventuate for whatever reason, Plasmaman do one, not as fancy looking, and a fair chunk of more cash is required when including the TB and other bits and pieces that are required to install it, but, it is another option that is available to me if FAB9 one does fall down (but I really, really.....really, want the FAB9 one though) TL;DR. You want what you want
    • Been so long since I have been here,seeing SDU is dead. I had that problem on my gtr in 2006 but luckily there was no engine damage,it was inspected by Hytech Engines,race bearings and extended crank collar put in and that was about it. Hopefully yours is sorted now.
    • Would it not be cheaper to just spray nitrous?
