After looking at some pictures of drift day i noticed one of the cars had a different pipe setup .. was wondering what the benefits of running your intercooler pipes this way would achieve.
im asuming its just so you can get easy access to your spark plugs with out having to pull the pipes off.
https://www.sau.com.au/forums/topic/50492-rb20det-pipes/
Similar setup was used on the Gibson Motorsport R31's, it seems to be the way to go if you want to run a shorter intercooler pipe for less lag and heat soak. It would save around
A number of guys are running a similar setup on the forum's with good results
Chris
https://www.sau.com.au/forums/topic/50492-rb20det-pipes/#findComment-1002692
That seems to do the trick, just a bit longer with the pipe work
A mate 33 was like that, it worked really well
At least it keeps the pipes out of the engine bay for as long as possible
https://www.sau.com.au/forums/topic/50492-rb20det-pipes/#findComment-1002708
wouldn't the bends negate any theoretic performance increase? I thought length is as important as air flow. That bend into the plenum doesn't really look helpful.
Dont be too concerned by bends= pressure drops. At the pressures, diameters and velocities we are talkign about you are talking less then a bees d1ck :D Provided it isnt a horrible mitred end, and the welds/fit up are ok, then bends wont hurt flow. :(
https://www.sau.com.au/forums/topic/50492-rb20det-pipes/#findComment-1002785
what do you guys think of piping that goes under the cooler and back in the original position?
like my Blitz kit? very easy to install. I think it works well as the hot pipe is the one that runs under the cooler so it gets cool before going through the intercooler. I guess it's more effective???
https://www.sau.com.au/forums/topic/50492-rb20det-pipes/#findComment-1004241
Ive got the same blitz kit, its really good and only took me about 1 hour to install.
In my opinion its effective as its avoiding engine heat a bit more, although I never thought that the length of the pipes would be that much to make a difference.
I think its a very efficient setup but I am open to more information!
take it easy
Mark
https://www.sau.com.au/forums/topic/50492-rb20det-pipes/#findComment-1004604
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
    • You miss spelled bearings...
    • Just putting it out there, that's a decent list. You would be better off *not* doing *any* of that and buying someone else's modded car. Like mine. Or anybody else's. Yes it's lotto dependent and all this and that but that 70K (remember, double your guesses) could go elsewhere. Keep it stock, save your money, go lowball @Dose Pipe Sutututu :p
    • Does not mean what you think it means. The continual rising coefficient is the coefficient of friction that continues to rise with increasing temperature. Not "rising during a single stop", except inasmuch as the brakes should get hotter during a single stop. The RR would not be the best choice for a streeter. Yeah....no it's not. JAX would rummage around in the "shit pads we use for all shitboxen that come in here" and install those.
    • @Kinkstaah I've got my list.. but most of them is to do if I ever win the lotto
