  • Replies 123
gor33, if u have a series 1 steering wheel then I think u can put the airbag into my steering wheel....I'd let it go for $200 - it cost me $350 to have it reupholstered. I'd like to sell the rear GTR badge with the boot lid.
I've taken all the seats out of the car...back seats are sold but the front are still available. The drivers seat has a small crack in the plastic on the side but everything else is fine...(seats need a clean now, but nothing a good scrub won't get rid off) all serious offers considered for these...
Most other parts still available....
I am interested in:
- Driver side power window button, inc. loom.
- Cigarette lighter (not the whole socket, just detachable part).
- Front indicator covers, assuming you have the round spot light type ones. Clear preferred, but may take orange depending on price.
Please PM or post prices for these items.
thanks for the comments Glenn, enjoy mate....
Guys the intercooler is back up for sale...I was going to put it on my R32 as the cooler on that car has some busted fins in a circle the size a 10cent coin, but I just did a smoke test through the cooler and it was fine!!!! I got my R33 cooler flow tested the other day at a radiator and intercooler shop who said that it was fine. They have cleaned it and given it a new coat of black paint. The damage is only minor now that I can see it properly. I will try to get pics of it....looking around the $600 mark for it....
Price drop on GTR intercooler $500.
Also, the car has an 80mm thick stainless steel cat back exhaust which is squashed in one section (about 15-20cm long) just before the muffler (canon muffler). This shouldn't be an issue to fix, just cut out that section and weld another piece of stainless steel. This will fit R33 GTS-T and GTR, chasing $400 entire exhaust (its about 8 months old)
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
