  • Replies 123
gor33, if u have a series 1 steering wheel then I think u can put the airbag into my steering wheel....I'd let it go for $200 - it cost me $350 to have it reupholstered. I'd like to sell the rear GTR badge with the boot lid.
I've taken all the seats out of the car...back seats are sold but the front are still available. The drivers seat has a small crack in the plastic on the side but everything else is fine...(seats need a clean now, but nothing a good scrub won't get rid off) all serious offers considered for these...
Most other parts still available....
I am interested in:
- Driver side power window button, inc. loom.
- Cigarette lighter (not the whole socket, just detachable part).
- Front indicator covers, assuming you have the round spot light type ones. Clear preferred, but may take orange depending on price.
Please PM or post prices for these items.
thanks for the comments Glenn, enjoy mate....
Guys the intercooler is back up for sale...I was going to put it on my R32 as the cooler on that car has some busted fins in a circle the size a 10cent coin, but I just did a smoke test through the cooler and it was fine!!!! I got my R33 cooler flow tested the other day at a radiator and intercooler shop who said that it was fine. They have cleaned it and given it a new coat of black paint. The damage is only minor now that I can see it properly. I will try to get pics of it....looking around the $600 mark for it....
Price drop on GTR intercooler $500.
Also, the car has an 80mm thick stainless steel cat back exhaust which is squashed in one section (about 15-20cm long) just before the muffler (canon muffler). This shouldn't be an issue to fix, just cut out that section and weld another piece of stainless steel. This will fit R33 GTS-T and GTR, chasing $400 entire exhaust (its about 8 months old)
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
    • The Frenchy's kit is the way to go forward. A modern compressor that weighs about 1/2 as much, is at least twice as efficient, and will do a good job on R134a. And of course the kit has everything else you need to connect it up and have it work properly.
    • Hey all , I am in the process of having the AC system in my r32 GTST converted from r12 to r134a and I’m being told my compressor has gone bad and I will need a new one. I was wondering if anybody has any suggestions for what is the best route to go aside from dropping $1500 on a new oem one? I did see that Frenchy’s performance garage offers a kit to mount a Toyota compressor, has anybody actually used this kit on their car? Or is there anywhere I could purchase just a clutch? Any help is appreciated.
    • Well, your RB20 ECU loom won't have wires for the boost solenoid, that boost sensor, and possibly one or two other things. There could be differences in seemingly random things like the charcoal canister purge solenoid, because the 25DET has to handle boost in the vacuum system and the 20DE does not. I don't know - I haven't looked. It is very likely that all the most important things are same-same, being the main sensors like AFM, CAS, etc, and the injectors and ignition. Not that you'll need the AFM for the Haltech anyway. I would suggest that you would seriously want to sit down with the pinouts for both ECUs and just go through them and highlight green what is the same, orange what is different/missing, and make a plan from there. It's not going to be difficult. It will either be the same or need to be fixed.
