How much is my toy worth?
I have a widebody Z31 in mint condition with the following mods putting out 475rwks at only 20psi and BP98 on a DD dyno
Some of the mods included are
Widebody kit
2.7L N1 RB26 with nismo oversized pistons
Full GTR twin TDO6/20G kit with 68mm external wastegate
Fully race prepped R33 gearbox to handle 1000HP
OS triple plate clutch
F-con Pro silver
GTR brakes all around
Lots of suspension mods
Fuel system for a 1000hp
The big trust oilcooler and relocation kit
Big trust RSP intercooler kit
nismo 2way LSD
And a tone more but you get the idea
This car has a very safe tune. The most amazing thing about this car is you can do 10back to back runs on the dyno and the intake plenum is still cool to touch
https://www.sau.com.au/forums/topic/50520-how-much-is-my-toy-worth/
I have had the opportunity to see this car in real life (and see it running, and see it on the dyno, it even has my old cat on it :rofl:) and it is a simply amazing machine. Not a cent has been spared on this car, I heard of it and before it actually arrived had it in my head it would be a bit of a rough conversion, but upon seeing it, its immaculate.
Definately a unique car, and its still streetable... when you want to let go of it make sure you tell me first :(
Interesting no-one has answered your original question!! This is a tough car, sounded great on the Dyno!! At a rough guess I would say the parts value is over 40K (just quickly in my head, not including the car). Very difficult to say what value anyone could place on the package - has the mumbo to runs some very low numbers on the strip.
If someone had the cash and were after a car to decimate the opposion (and appreciated / was a Zed enthausist), then I'd imagine ~38K-55k??? hard to put a price on it, you need to look at the cost of building up something similar...
What about you ljstt & Amaru?? Anyone else??
come on DANOOH its a bit like asking how long a piece of string is, with out knowing every detail its impossible to know what its worth, is the paint perfect, has the interior been upgraded at all, do you have any proof like photos of build to prove it has what you claim etc etc or was it imported like this and you are passing on the list of mods you were told its meant to have
As for my question about the gearbox, I know of a car with same turbo set up that blows 3rd gear in a trust gear box just coming on boost so without exact specs and detailed pics how can anyone know what price its worth or isn't worth :rofl:
yeah point taken but i'm just looking for some feedback and some ballpark numbers.
The car was built in Japan, I even had it down tuned and a new nismo 2way LSD done before it arrived. Like I said its in mint condition I spent 1k just having this thing inspected in japan.
Anything over 7000rpm in 3rd and even 4th gear you have to go easy on the gas or it brakes traction.
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
