  • Replies 54
C'mon guys. Yes this is expensive for a powerfc. but thats when you compare it to the models which apex actually made a unit for. you might be able to get this slightly cheaper through an importer, however you would have to wait a few months to get it. this is unit is here now, ready to be installed.
  • 1 month later...
KIL.08S: ive got an f-cvon v pro gold on my rb20 in my 32... wont be here till january if you can hold out - pm me
Cerbera: an AP engineering let alone a normal PFC for 700 wouldnt be the easiest to find... how insulting
Aybee id buy it but id rather buy a brand new one from greenline.jp for 1650 to my door
- adz
its a ap engineering unit isnt it...
so it suits gtr injectors (low impedence only) yes?
Ah no, it suites the standard GTST injectors, same as the standard ecu. Power FC's are always plug and play. As per usual, you can use GTR injectors with the GTR resistor pack.:rant:
considering that u can get a AP engineering unit for under $1200 new , why would $700 be such a insulting offer, its 2nd hand after all. supply and demand, if noone else wants it then its not worth anything!
sydneykid:
from www.greenline.jp
"A.P. Engineering Special. Manual transmission only. Only compatible with low impedence injectors."
    • If you're really considering leaving it, a great question to ask is, is the magnet going to stick to the sump? The answer to the above is the same answer towards if I'd have any level of comfort leaving it... Personally, based on the cost of a motor if the magnet were to cause damage, I'd be fishing it out either way. Use the methods in here. It fit in through the plug hole, it'll come out.   PS, get a small actuatable claw for a bore scope. OR if you know a vet, they have really cool controllable scopes with hooks on the end. Supposedly they're like playing a video game. Ask if they can acquire you one of their scopes... Engine oil after all is just a different type of lube right? Will only make it easier on the next dog or cat...
    • All other (Boolean) logic functions though, are just built on those blocks above. Which does give you a lot of functionality in logic. It is basing that on using thresholds with analogue signals like GTS alluded to.   Not having things like timers will make it less useful for some of the ramp up logic you'd want, and again, on Haltecs capacity specifically, I'm not across anymore what you can / can't do with different tables.   I'm assuming, with your logic you want to implement, not only do you want your timing safeties, you're wanting to be able to derive the duty cycle for your solenoid, to maintain I'm assuming 175PSi? Or are you using a standalone WMI controller to maintain the DC correct, and you just want the Haltech working out which fuelling maps you should be on?
    • It doesn't seem to follow revs. Oddly it seems to follow TPS a little bit from what I can see, but with some delay a bit. IE end of the graph, when he lets off throttle fully, pressure drops a lot, then slowly builds back up, but rpm is on a nice cruisey drop off. I do agree though, it seems very electrically.
    • I just try to entirely stay away from ladder now unless it's something basic maintained by electricians. Even then and to your point, it mostly ends up being blocks I wrote in structured text.  PLC's are slowly going towards C, C++ and C#. I just wish Allen-Bradley would jump on the bandwagon.
    • All of them are missing. You do not get much done with just AND, OR and NOT unfortunately. Ecumaster for example has a text based editor with at least 60+ math and logic instructions.
