I have an R34 (auto) and want to change the transmission oil...can anyone tell me if there is a drain plug on the trans or do i have to drop the bottom pan on the trans and drain the oil that way then replacing the gasket on the trans...any help would be appreciated.....
Could anyone also recommend any sort of oil to run in the transmission...
Thanks
https://www.sau.com.au/forums/topic/50548-r34-transmission-oil-change-help/
if you want to get this done at a mechanic PM me as my mechanic (from the highpoint area) did mine no probs so hs done a skyline auto before. i can give you his details.
as for your question:
when mine was done, the sump was dropped to dran the oil. the old gasket was stuck like you wouldn't believe so had to be scraped off, and the filter and gasket replaced. Don't know what oil he used but he gets it in barrells. He used mbil 1 for enging oil so i assume he has a contract with mobil for gearbox oil also...
good luck!
Warren.
Ps you still live near taylors lakes? i haven't seen your car around for a while... (white R34 with no spoiler right?)
Take the hose off the transmission cooler at the front of the car and point it into a bucket.
Put the transmission in neutral and start the car.
When the fluid stops pumping out it's empty.
If you use the drain plug only about 3/5 of the fluid will come out.
You don't put oil in auto transmissions.
I'm about to put Redline High Temp ATF in mine and I'm expecting good things. Sharper shifting, less slippage. Will let you know.
  • Thanks 1
Yeah sorry i meant to say fluid....any way this way sounds easier then pullin the bottom pan out...is it safe to run the car in netrual with no fluid while its draining?...
Another question...ive got a seprate transmission cooler which i wanted to put on..is it as simple as removing one of the hoses from the bottom of the radiator and connecting it to the cooler and the connecting the other side back into the radiator??... making it like a loop??....anyone had any experiances with trans coolers.. are they worth puttin on?
You already have a transmission cooler.
Are you going to the track?
I have been to several track days and only once had the auto light come on which a couple of slow laps fixed.
I'm thinking of putting a bigger one on myself at some stage though.
I don't understand what you mean by your references to your radiator there.
Apparently it's safe to do the above.
Oh ok...i thought that it works in the same principle as an R31...which the fluid runs through the bottom of the radiator (i think)...The trans cooler i got is off a R31GTS which works through looping it through the hoses at the bottom of the radiator...i thought the 34 would have worked on that same principle....sorry if i confused you or anyone else
About 5 litres if you pump it out as above or about 3 if you drain from the sump. Now you can see why it's better to pump it out. This is the 34 box. It's different from the 33 box but I have no idea how different.
Thanks for the help Abo Bob....will try it out in the next couple of days....
Hey Warren...i dont live there anymore i moved out from that area... my 34 does have the rear spoiler on it....there was another one in the area without a spolier so it must have been that one that you saw
Hi mate, if u ever try flush the transmission before, i think u should do one for your transmission. Because each time when u changed the transimission fuild, u only could get about 50-60% out, so there still have about 40% old fuild left in the transmission. After u put the new fuild in, may be a couple of months the fuild will get dirty again. And at the end u will end up with the transmission problem, or f**k up the transmission early.
In my opinion if u havent try it b4, U should go to the spealist transmission garage to change ur fuild, i meant the shop who has the machine to change it. By doing that u could change about 90-95% fuild out of the transmission.
After changed the fuild , u could actually feels the transmission shift better and smoother.
Hope that help.
steven
  • Thanks 1
Well I did mine on the weekend and you might just be right Steven.
I did the drain thing from the transmission cooler (it's the top hose you take off) but only 3.5L or so came out. I then took off the sump bolt and there was none left in it.
After I put the new fluid in I noticed that I could have taken off the dust cover that sits between the sump and the bell housing (about 10 bolts as there looks to be some stiffening brackets there) and got to the torque converter. I don't know if this would have done me any good but I'm sort of expecting that there might have been a drain plug in the torque converter itself so you can get the rest of it out.
I wasn't trying to make mine shift smoother I was trying to make it shift harder. To this end I did get some improvement although perhaps not quite as much as I had hoped for. I guess this is because of the fluid I couldn't get out.
For the info of people out there I poured the new fluid down the dipstick pipe no worries.
  • 1 month later...
Workshops have a pump they use to pump it out of the torque converter.
I have 12 liters of Redline Hi temp in the boot of the car, and i'm looking for a workshop that has that pump, but no luck so far.
One would think that all automatic gearbox specialist should have one.
The ones i spoke to so far use the same methods Abo Bob used.
If anyone knows of anyone in Syd west, please let me know.
Guest RedLineGTR
I was under the assumption that you only needed about 8 litres??
RedLineGTR - They come in 4 ltr cannisters so I bought 3 just in case I need 9 litres. I'd hate it if i started the job and wouldn't have enought. I guess better be safe than sorry.
If i don't open the last one i can always return it back to the shop.
Guest RedLineGTR
Ah sweet not a problem :(
Update on the fluid change.
Finally I found a guy who had the machine to get all the fluid out of the trans. The problem is, if you use the machine you cant get the filter, gasket & the pan cleaned.
So on his recommendation I got this done first, and he put in some Castrol oil. After a few weeks I’ll go back and get the system flushed and put the RedLine Hi Temp fluid.
My pan had a shitload of some goldish sparkling stuff on the bottom of it and a 5cm piece of the dip stick – what the ****.
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
