Ok i know this has probably been asked a million times but im just after some feed back on this. What are people opinions on machining discs? I have replaces more sets of brake pads than i car to remember but have never machined the discs. Generally if there are grooves or bad scores or so on i have always ended up doing just replacing the discs. Now through my work i know of alot of workshops that simply machine discs as part of a pad change, i dont really aggree with this but some workshops do it.
Also what procedure do people try to do when bedding in say a set of bendix pads?
https://www.sau.com.au/forums/topic/50560-disc-machining-and-bedding-pads/
I personally believe that if the surface of the disc is near new, leave it and just change the pads but if the ware area is recessed or there's any scoring, do the machining. I've seen someone put new pads in on recessed discs and try to bed them in only to break away the inner and outer edges of the pads.
Also, I only machine a set of discs once if the car's used for track use etc. I've found that with machined discs and heavy braking they don't take long before they get heat cracks and/or start to warp.
My personal preference for bedding in brakes is to drive the car normally for about 50-100 km and then do some very heavy braking down from 100 kph + to about 20 kph but NOT stopping completely. Instead, I just keep driving so the discs don't get too hot. This is usually enough to bed them in I've found. This is also the way I was taught to bed in the barkes on Ferrari's and Lambo's back when I was a spanner monkey.
Again, this is only my personal belief / preference. :rofl:
    • Seemed to be good when Jeff owned it but they did a shit job on my car, probably worth a think before spending 10's of thousands of dollars where they might be cutting corners
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
