Hi
I'm getting my car dyno tuned very shortly and the mechanic asked me what fuel i usually run. I said optimax. He said that they tested fuels and for the best tuning results it was.
1. Ultimate
2. Synergy 8000
3. Optimax.
Now i've done a little searching around on the net and it seems that it's a fight between Synergy and Ultimate for the best tuning performance.
Now to be vehicle specific with skylines... Can any1 post what they've had their car tuned to and what their mechanic said about tuning with certain fuels.
Cheers,
  • Replies 46
On 3 occaisions I have used Optimax and during all three my car ran like shit, It also caused my cat to stuff up.
I have used Ultimate and it seems great, although I always used Synergy without a doubt as its always been great with my car.
take it easy
Mark
Hi
1. Ultimate
2. Synergy 8000
3. Optimax.
Cheers,
Yeah thats probably the same order I'd use them as well. Ultimate is probably more difficult to locate but only optimax if I cant find the other two
I always run Ultimate but will settle for Synergy 8000 if that's all I can find.
Optimax has given me less than good results. It's a shame though because it's easy to find where I live but I have to drive 5k's to get Ultimate :cheers:
I have found Ultimate to be the best out of the
Ultimate vs Optimax battle..
I was once informed that Optimax is 'Up to 98 ron'
where as Ultimate 'Is 98 ron'
Anyway my advice is, pick a petrol and stick to it .. dont keep changing fuels or alternating between synergy and ultimate.
I have also found...
shit.. i forgot what i was going to say :cheers:
Currently using Synergy8000, was usung optimax for ages.....noticed the fumes (exhaust) did actually smell more, an the synergy8000 runs cleaner. Not really fussed between Mobil or BP 98 fuels, both seem to be a good product. But like most, only opt for Shell when have to.
Never had any experience with synergy, but I have talked to a couple of people in the know and basically what I was told was that Ultimate is refined to get 98 ron and Optimax just uses additives to get 98 ron. For this reason the Optimax will lose ron faster then Ultimate.
Everything I have read on public forums indicates the ultimate fuel to be the superior product.
But for some reason I get a noticeable improvement in fuel economy with optimax. Approx. 1-1.5km/L better.
I have seen many people mention the arguments about the optimax being "up to 98ron" and that it has additives to raise the ron level and ultimate is refined to 98 ron.
Does anybody have any documentation or links on the web to support these claims?
    • Last year I got a set of MCA street coilovers for my turbo Forester after my son hitting a concrete gutter/wall on a small bridge causing the whole drivers side suspension to get bent because the rain just made the car slide out I love them, I think they were $2400. even had a hiccup of have the wrong hub configuration (my fault) so got onto MCA and they sent the correct shock ends overnight parts from QLD, for free!  I was very impressed with their customer service and quality of the product
    • They've had some weird failures on their brake actuators. One of them was because they added some kind of lubricant to the factory fill brake fluid that aftermarket brake fluid didn't have so it would affect the seals. Another was just mysterious, probably internal corrosion or something eating away at Prius brake actuators. Parts alone for those are a few thousand USD so not a cheap fix.
    • Selling a genuine Nissan Skyline R33 Coupe 8-Pin Power Window Master Switch Part No. 25401-26U10 Price $300   IMPUL Gear Knob – Rare JDM Upgrade Upgrade your interior with this genuine IMPUL gear knob – a rare and stylish addition to any JDM build. Premium quality, perfect fit, and an authentic Japanese touch for your ride.  Price:$300 Nissan Skyline R33 (Series 2) Sedan Tail Lights Immaculate Condition OEM JDM S2 a pair of OEM Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state. Price:$900   Located in Melbourne (Western Suburbs) – Shipping available Australia wide at buyer’s expense. DM if you need anymore details.
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
    • That's not very Toyota of the Toyota!
