i have a hks air filter ... it is one of them high flow ones which makes a nice sound when the air is suckin in .. it has this green spongy material inside ... i was wondering what chemicals i need to use to clean it ... and how to actually clean it ... i don't know when it was cleaned last ... my friend says that my engine will be running dirty because its high flow and because of the actual material ... is this good for the engine??
thanks
can be seen here
http://www.inlinefour.com/hkssupmegflo.html
https://www.sau.com.au/forums/topic/5064-hks-air-filter/
Ok dont tell anyone......
U can clean them was it with soapy water.......they are a wet type filter which needs to be wetted with an oil which u can get from rev racegear or the like. If u clean then no oil ur engine wont like it ie cold gravel intake :)
U are supposed to replace them as G0DF4Th3R says around 20k but if the material is in good nick u can clean n re oil
https://www.sau.com.au/forums/topic/5064-hks-air-filter/#findComment-78759
hmmm ... so how much do one of them apexi ones cost?? are they noisy?? i seem to like the sound that the hks one gives me ... i can really hear the high pitch sound sucking in ... so i like it ... since the hks one causes the engine to run dirty ... how does that affect performance and engine condition??
thanks for that great link!! .. i hope to see u guys on a cruise sometime :D
https://www.sau.com.au/forums/topic/5064-hks-air-filter/#findComment-78842
I think The Apexi Power Intakes are a bit cheaper and they are also much quieter compared to HKS.
GTR-80Y Bad move! If there is no seal between the filter and air tract it defeats the purpose of having an air filter...Even the smallest bit!
It Seems that the grainer filters need the oiling your hks filter for standard airbox may be a dry one but you should search the web to be 1000% sure!
https://www.sau.com.au/forums/topic/5064-hks-air-filter/#findComment-79161
hi,
its ron here.
for the HKS filter, which i do have.
the best way to clean is with degreaser. do a couple of times orso
then leave til dry. oil it with air filter oil, can be found at motor shops.
these filter are pretty much the best on the market so you dont need to replace them.
i dont oil mine and found that topend power is greater, also build a cold air box for best results. and if you have a front mount, feed the air through the hole where the old pipe goes.
hope this is useful
regards
ron
https://www.sau.com.au/forums/topic/5064-hks-air-filter/#findComment-82213
