i will write those down and stick them to my monitor so that i dont forget them
are there any other mods that a stagea owner should conisder doing to imrove handling and general performance such as the brakes. do they need to be upgraded or are they quite good
Ours has new DBA rotors (not slotted) front and rear and unknown (but new) pads. It stops pretty good for an automatic 1,650 kg lump. Handling wise, as I said in my previous post;
Std Springs = OK
Shocks = Bilsteins with extra grooves to adj height
Fix Roll = Stabiliser bars
Turn in and light steering = more caster
+ Check wheel alignment after lowering to see if camber adjustment needed.
I might try one of those nifty torque split controllers like we have on the race GTR's. They are fun to play with, if somewhat confusing when you also have adj stabiliser bars, adj shocks, numerous spring rates, adj camber and adj caster. Makes my brain aches just thinking about it. :headspin:
Better brake pads all round would be good enough for a street car. From what I notice reading the specs lastnight, and I guess giving it a bit around the track...IIRC HKS Kansai just changed the front to F50 Brembo calipers, rear remained standard and used project mu titan pads all round. Will look more into their handling and braking setup tonight :D
edit: had a look at the brake setup of the cars I mentioned in the list, either better pads for mild tune or Brembos for the hi-power tuned ones...if you can afford to tune that much power you'd want to be able to stop :).
I drove mine a bit before putting the Pod Filter, Front Mount and Full 3" exhaust back on what a difference it makes, sucks the juice as we all said but it happens. The Boost controler is to go back on so a bit more to come.
I put 225's on instead of usual 205's on at time of compliance, well it sits so low since I put the coilovers back on I cant put 3 people in the back.
New R34 GTR seats with Stagea Rails, arive this week as Jeff at www.c-red.com.au has tracked down company who built ones for Nissan and are now selling new, quite well priced but need to order 6 set's and Sea freight to keep price down.
All I know is Jeff said "I will order the seats and a set of rails to suit the Stagea" if they are just a bolt on or not I am not sure, at the price I was more than happy to have seperate rails.
If somebody wanted them for a 32 and it was direct fitment it is easyier to sell with rails.
I learnt over the years to buy seats with rails.
Good stuff - you'll love it when you pick it up.
I was out at the exhaust shop today (wooohooo, booked in on 21st Sept for a full 3 inch system :) ) and got talking to the owner about the car. One of the workshop blokes was looking under the car and said 'hay - this has a skyline motor in it..., DAMN and it's 4wd !!!"
I had a big grin on my face... :cheers:
When I told them how much they sell for they almost fell over...
Once the word get's out I dare say there will be a few more going around :)
J
I imported it myself, Hey Mad Wagon did you get yours from preferred autos on bribane road, my dads cousin works there, I think i may have seen your car on their lot.
Currently its with Ernest (my compliance man) at Skyline imports in brisbane (southside) So i got to go get it and rego it on thursday providing the plate arrives on time.
The only problem is i'm working most of the weekend! GRRR Last fri night I was mixing for some international Bosnian band at Southport sharks til like 2 in the morning then worked all saturday. This saturday i gotta work most of the day then have to DJ at some function at the casino til like 3:30am on sun morning. Hmm could be a sleepless weekend. Must go cruzing sunday arvo maybe. Got mods to start and stereo to install aswell.
At least i'll have it in my hot little hands. Then I can truly become part of the club.
    • Thanks heaps Duncan and GTSBoy. I'll get my old man to sit in the driver's seat and turn it on and off while I test with the meter. Or maybe other way round, depending on whether he remembers where his glasses got to
    • This is the GTR fuel pump. Yellow shows 12V, orange shows earth. The ECU provides the earth to activate the fuel pump relay. The ECU side of teh relay will pull low when the ECU activates. This is the RB20 fuel pump. Almost the same, but a little simpler. You can see I indicated (above) where the 12V line goes down to the RB20 diagram on the overall diagram, whch shows both RB26 and RB20. This is where I show it coming in on the RB20 diagram below. You can see that the dropping resistor is handled differently. When the fuel pump control is not providing earth to the pump, the pump earths through the dropping resistor and thus runs at lower voltage (some is wasted over the resistor) and runs slower. I showed that "not 12V and not quite earth" portion of the wiring in a paler orange. The rest of the wiring that I did not colour on that little section below the pump would be orange when the fuel pump coontroller is providing earth. This drop is handled inside the fuel pump controller in the GTR. Regardless, you can see where 12V is supposed to be, where earth is supposed to be. The key on prime is via the ECU providing the pump for only a few seconds the switching off. You should be able to see that happen.
    • Yeah so when you turn key to IGN the fuel pump should run for a few seconds. If you find the fuel pump relay (and have a multimeter, and a second person) to can check the relay inputs.  One trigger pin should be either fully earthed  The other trigger pin should get 12v from the ECU for say 3 seconds when you turn key to IGN, and at all times that key is at START (note, I said this from memory, it may be the other way around, ie one pin always has IGN 12v and the earth has continuity to earth when you turn the key) One Pin should have a good battery voltage The last pin goes to the fuel pump + Also note that if the power to the relay is good, and the relay is working, it is worth checking the pump has a good earth too. There is a computer in the standard system that increases the earth resistance to slow down the pump when not required, pretty old school and it may have failed
    • All this talk about fuel and fancy ECUs, meanwhile my poor old R32 has neither.... When the ignition is turned on, should there be power running o the fuel pump constantly or just for the few seconds it usually takes to prime the pump? About to go have another look at it, have watched some YouTube vids on how to use a  multimeter and looked at some wiring diagrams but really have NFI what I'm looking for because electricity is invisible
    • Yuh....but weren't all the supertourers, except maybe the Audis, FWD? I don't recall any of the others being AWD.
