i will write those down and stick them to my monitor so that i dont forget them
are there any other mods that a stagea owner should conisder doing to imrove handling and general performance such as the brakes. do they need to be upgraded or are they quite good
Ours has new DBA rotors (not slotted) front and rear and unknown (but new) pads. It stops pretty good for an automatic 1,650 kg lump. Handling wise, as I said in my previous post;
Std Springs = OK
Shocks = Bilsteins with extra grooves to adj height
Fix Roll = Stabiliser bars
Turn in and light steering = more caster
+ Check wheel alignment after lowering to see if camber adjustment needed.
I might try one of those nifty torque split controllers like we have on the race GTR's. They are fun to play with, if somewhat confusing when you also have adj stabiliser bars, adj shocks, numerous spring rates, adj camber and adj caster. Makes my brain aches just thinking about it. :headspin:
Better brake pads all round would be good enough for a street car. From what I notice reading the specs lastnight, and I guess giving it a bit around the track...IIRC HKS Kansai just changed the front to F50 Brembo calipers, rear remained standard and used project mu titan pads all round. Will look more into their handling and braking setup tonight :D
edit: had a look at the brake setup of the cars I mentioned in the list, either better pads for mild tune or Brembos for the hi-power tuned ones...if you can afford to tune that much power you'd want to be able to stop :).
I drove mine a bit before putting the Pod Filter, Front Mount and Full 3" exhaust back on what a difference it makes, sucks the juice as we all said but it happens. The Boost controler is to go back on so a bit more to come.
I put 225's on instead of usual 205's on at time of compliance, well it sits so low since I put the coilovers back on I cant put 3 people in the back.
New R34 GTR seats with Stagea Rails, arive this week as Jeff at www.c-red.com.au has tracked down company who built ones for Nissan and are now selling new, quite well priced but need to order 6 set's and Sea freight to keep price down.
All I know is Jeff said "I will order the seats and a set of rails to suit the Stagea" if they are just a bolt on or not I am not sure, at the price I was more than happy to have seperate rails.
If somebody wanted them for a 32 and it was direct fitment it is easyier to sell with rails.
I learnt over the years to buy seats with rails.
Good stuff - you'll love it when you pick it up.
I was out at the exhaust shop today (wooohooo, booked in on 21st Sept for a full 3 inch system :) ) and got talking to the owner about the car. One of the workshop blokes was looking under the car and said 'hay - this has a skyline motor in it..., DAMN and it's 4wd !!!"
I had a big grin on my face... :cheers:
When I told them how much they sell for they almost fell over...
Once the word get's out I dare say there will be a few more going around :)
J
I imported it myself, Hey Mad Wagon did you get yours from preferred autos on bribane road, my dads cousin works there, I think i may have seen your car on their lot.
Currently its with Ernest (my compliance man) at Skyline imports in brisbane (southside) So i got to go get it and rego it on thursday providing the plate arrives on time.
The only problem is i'm working most of the weekend! GRRR Last fri night I was mixing for some international Bosnian band at Southport sharks til like 2 in the morning then worked all saturday. This saturday i gotta work most of the day then have to DJ at some function at the casino til like 3:30am on sun morning. Hmm could be a sleepless weekend. Must go cruzing sunday arvo maybe. Got mods to start and stereo to install aswell.
At least i'll have it in my hot little hands. Then I can truly become part of the club.
    • Do the following first and get back to us. - Clean and verify your IACV - Verify for vacuum leaks/post MAF leaks. (Pressure test is the best and cheapest way) - Do you have a BOV with stock ecu/MAF? If so, remove it.
    • Hey all, The skyline I have is stalling when the engine is at normal operating temp.  When starting it while it is cold, it'll run just fine.  I have replaced the battery (bad cell), I have replaced the fuel pump, fuel filter and clean the MAF sensor.  Any other suggestions?
    • Thanks for all the information on this.  I tried ordering the parts from Amayama website and all 3 Solenoids are discontinued and not available.  Does anyone have any other websites to suggest that I could find the parts?   Separate issue-- I will start a new thread, but basically the vehicle is stalling when warmed up.
    • It's unfortunate what Tomei USA has done to Tomei's name in general. I'm very weary of ordering parts from them now. I only order direct from a Japanse source (e.g Nengun). At least their logos are different, so you end up knowing what you have.
    • Update Issues 5 (plus #4) - 10 After making a claim about issue #4's missing part, DeAgostini Japan sent a whole new issue #4 and it arrived about 2 weeks after that. That was back in early March. It took another 4 weeks to receive issues 5 - 13 though. This update is for issues 5 - 10. Ove the 5 issues the front left suspension and most of the engine have been completed. The quality of the castings and fit of the parts is quite good, it seems better than DeAgostini's BNR34 Skyline GT-R from the Fast & Furious 2 movie, which (to me anyway) doesn't seem to have as tight tolerances or quite as accurate castings.  Each issue has a lot of info about the 1989 - 1993 Skyline range and other Nissan models from that era, but the focus is on the BNR32 Skyline GT-R Nismo and the various racing it did in Japan, Europe (Spa 24hrs) and of course Australia. I've included some text translated with Google Lens in some photos and will add to them if there's anything worth including.
