http://www.autowholesale.com.au/ will have it soon as they have had one in for a while and if you email [email protected] Albert Balducci or the RAW CAM [email protected] and Frank will know more but plates are short so dont expect to get one easy.
what do they sell for out of interest and is there any real benefit for going for the series two over series one?
i know the stock engine is a neo spec on the series two meaning more power and torque and the gearbox is a tiptronic but is there any other differences that would make them more popular?
personally i hate the headlights on them they look weird
They are here now, just cost more than series one, I dont think untill the price comes down will they be popular.
I know, and my mate was mighty pissed off to hear that.
I did tell him to buy a M35 but he didn't like the interior. His Series 2 C34 was by no means cheap too, cost him 2Mil yen...absolutely immaculate, grade 5, no damage history, paint was like new, volks wheels, 28,000km (extremely low for a 1999 model) and it is an Auto too so you can imagine how much a mint manual will cost.
edit: you mean affordable...we know they are already popular! that's why he bought one ;).
your mate didnt like the m35 interior??? WTF!
the m35 interior is great but i bet that those sweet navigation screens that pop out of the dash wont work when they get here :D
    • I'd say the easiest way is, pick up a extended and baffled sump with fittings already welded on. Here is an example, it has 3 x -10 fittings  https://shop.maatouksracing.com.au/products/rb-extended-and-baffled-sump
    • hey OP can you remind me what the actual question was, I got sidetracked at V12. Do you have an turbo oil return leak and an unidentified coolant leak? The factory oil returns are terrible design; short, rubber and expensive to replace. They are very common to fail and a pain to replace because they are so short. Still, they are available new if you want to replace both last time I checked. For the coolant leak, any competent mechanic should be able to do a pressure test; that should show up where the leak is. It is almost certainly one of the billion 30 year old rubber lines which are now brittle as hell, you engine will be fine.
    • From the OP's description, sounds to me like the TCU is in 'limp home' mode --- that is, no actuation power to shift solenoids, and the EPC valve is shut (full line pressure). This effectively sticks the box in 3rd gear, with as much line pressure as possible, to try hold the high clutch clamped shut....and so you get woeful acceleration and don't feel any shifts (because they're not happening). If you don't have Consult or some other scanner to interrogate the TCU itself, you can test with a multimeter to see if it's in limp home mode....ie; stick it in D with engine at idle (hold vehicle with hand/foot brake), and measure the voltage at the TCU feeding shift solenoids A & B -- both should be ON (battery voltage). If they are energized at the TCU, you can unplug the harness from the TCU, and check resistance down through the wiring to the solenoids themselves -- you should see about 20ohms on each coil --- if you do, you can presume the wiring to shift solenoids is OK -- if both measure open circuit, you have to check intermediate connectors in the loom down to the gearbox (and the gearbox connector itself), and check the shift solenoid resistance at the gearbox connector itself --- if the shift solenoids test open circuit here, problem is in the box (ether the solenoids or wiring to them is bad). If you get no voltage at TCU connector for the shift solenoids (and the solenoids/wiring test OK), check powers/grounds to the TCU itself --- if they're ok, it suggests the TCU is the culprit (and you'd need to interrogate it if possible, to find out why it's behaving badly)...
    • Hey mate give Autotechnica a go, I recently got some Comfort PUs and rails from them, they're comfy and look great highly recommended! https://www.autotecnica.com.au/part-finder/nissan/skyline/r32/
    • Honestly, for a daily I would gladly rock a Camry. The more disposable the better. People drive horribly out here and road conditions are awful.
