No, the RB30ET uses a different (larger) flywheel. The clutch also isn't compatible.
If you're in a desperate pinch, the RB30E clutch bolts up to the 25 flywheel, the difference being (apart from lower clamping pressure) is the RB30E clutch uses 6 bolts to attach the pressure plate to the flywheel whereas the RB25DET clutch uses 9 bolts.
https://www.sau.com.au/forums/topic/5070-rb25det-flywheel-q/#findComment-79292
