just a question for the ill informed
what is the difference between awkw and rwkw?
obviously the rwkw calculation is at the two rear wheels but awkw if at all 4 wheels so is the calcualtion different.
I must admit i am very interested to find out about this.
is anyone can fill me in i would muchly appreciate it
https://www.sau.com.au/forums/topic/50701-awkw-vs-rwkw/
When you put a car on a chassis dyno (roller or hub style) there are power losses, in the gearbox, the tailshaft universals, the diff, the driveshaft universals, the wheel bearings, the tyres and the rollers themselves. In a 2wd Skyline (like na R33 GTST) this works out around 50-60 kw, based on the cars we have tested. A couple of which we have also run up on the engine dyno confirm this.
Obviously when you add a transfer case, front diff, front drive shaft universals, front tyres and the extra rollers you loose more power. Around 20-25 kw based on what we see with GTR's.
So if you have a 280 kw engine, it will show around 220 rwkw and 200 awkw.
I should point out that there are no "losses", Newtons law applies, "energy can neither be gained nor lost". So the 60 kw is not "lost" it is transformed into other types of energy, in the car's case that's generally heat.
Hope that is of some help :D
https://www.sau.com.au/forums/topic/50701-awkw-vs-rwkw/#findComment-1006141
yeah that makes sense
so basically like when your talking about a rwd drive car and you can make an estimate of rwkw by working out an aprroximate powerloss percentage thru the drive train the same applies in the awd but there is more areas for power loss
btw whats the stock kw at the engine for a 34 model stagea series one and whats the awkw stock as well if you know
:D
https://www.sau.com.au/forums/topic/50701-awkw-vs-rwkw/#findComment-1006207
so basically worst case your going to allow for about 80-90 kw loss on a stagea?
just trying to figure out what i will need to spend to get to my power figure i would like
finally convinced the missus to get an import and the stagea looks like the most logical car for us plus having the awd and turbo is a huge bonus
thanks for the quick replys guys
https://www.sau.com.au/forums/topic/50701-awkw-vs-rwkw/#findComment-1006229
whats the stock kw at the engine for a 34 model stagea series one and whats the awkw stock as well if you know :D
That's a good question mcnamg. I have seen 185 kw and 173 kw quoted for Stageas. I am going to run ours up on the 4wd dyno next week, while it is standard. I expect to see around 100 awkw. I will then drop the exhaust from the front of the cat and do a quick (and noisy) run to see what's in the exhaust upgrade. If I have time I will stick the Pipercros panel filter in and see what difference it makes at standard power, not much I expect.
I'll post it up when done. :(
https://www.sau.com.au/forums/topic/50701-awkw-vs-rwkw/#findComment-1006230
Just interested with your test data, was it tested using stock clutch or aftermarket clutch? and was it auto or manual? Cos my auto when it was 100% stock was suppose to have 184kw and it made 138rwkw on dyno, so I'd imagine manual example should made well above 140rwkw with a good stock clutch.
https://www.sau.com.au/forums/topic/50701-awkw-vs-rwkw/#findComment-1006546
SK, I dont know how you find the time to contribute so much to this forum!
Thank the great spartan air god you do!
My question is,
if my AUTOMATIC GTS4 made 170 RWKW (AWD fuses Pulled) on the dyno and ran 14.1@98Mph(0-60/2.6) at the drags, what sort of AWD KW do I need to make to get into the high 12's??
And, what would the difference in times be between AWD and RWD(fuses pulled) if I did manage to make 250 AWKW? (My long term goal for my Stock bottom end RB20)
https://www.sau.com.au/forums/topic/50701-awkw-vs-rwkw/#findComment-1006584
Thanks heaps for all the information would be very interested to see what your cars power figures are like when you dyno it
when you post it up post the dyno sheet if u got it
can you also tell us what zorst u are using as well just to give us an idea of whats power it is capable of adding to the car
:P
you seem to be an absolute hive for information. I suppose its good that someone knows this information because if not we would still be trying to translate one of a million japanese car sites to english to figure it out
https://www.sau.com.au/forums/topic/50701-awkw-vs-rwkw/#findComment-1006678
Hi rs73, clutch is irrelevant, as long as it isn't slippimg of course. Auto's seem to loose around 10 kw more than manuals, if the torque converter locks up solidly maybe a few less. And lastly, all dyno's are different and climatic conditions make a difference (not withstanding DynoDynamics good attempt with Shoot Out Mode). So your 184 - 138 = 46 kw is well within tolerances.
Data source, we have run 2 X RB26DETT's on the engine dyno and then put them in the GTR and one RB30DET and put it in the GTST. Along with untold Holden and Chevy V8's (both big and small block). Plus over 30 Skylines (standard and modified) on the chassis dyno only. So I am pretty confident the data base is large and the results consistent enough to make a judgement.
Hope that helps :mad:
https://www.sau.com.au/forums/topic/50701-awkw-vs-rwkw/#findComment-1007098
I only sleep 4 to 5 hours a night, take a look at some of the times I post at.
That's a tough call, average power makes more difference than the sinlge max power number and RB20's get narrow in their power band as you move up the max power ladder. I would think 200 rwkw would do it, but it might need 210 rwkw if the auto isn't transferring the power well.
My experience (and I am not a drag racer) is the traction from 4wd makes more difference than the power losses by a good factor. Your target of 250 awkw is getting up there for an RB20. That's ~410 bhp, I have only ever seen 1 X RB20 make more than that and it didn't have standard internals. Ours makes 225 rwkw with good average power, it is tricky to get off the line and you really need to be paying attention to keep it firmly in the power band. The auto and 4wd will assist you there.
Hope that is of some help :mad:
https://www.sau.com.au/forums/topic/50701-awkw-vs-rwkw/#findComment-1007099
I only sleep 4 to 5 hours a night, take a look at some of the times I post at. I would think 200 rwkw would do it, but it might need 210 rwkw if the auto isn't transferring the power well.
My experience (and I am not a drag racer) is the traction from 4wd makes more difference than the power losses by a good factor.  Your target of 250 awkw is getting up there for an RB20.  That's ~410 bhp, I have only ever seen 1 X RB20 make more than that and it didn't have standard internals.  Ours makes 225 rwkw with good average power, it is tricky to get off the line and you really need to be paying attention to keep it firmly in the power band.  The auto and 4wd will assist you there. Hope that is of some help :D
Thanks, SK :)
If I can make 12's with only 210AWkW I will gladly reduce my expectations and COST ;)
Its easy to throw numbers around and 250 didnt sound too much to expect from reading ZOOM etc. on their experience with RB20's.
The Auto has been completely rebuilt with kevlar clutches , 2800RPM Stall etc so should do the job and handle any power the RB20 can throw at it.
AS my GTS4 is reg as a GTR I probably should put an RB26 in it and have an Auto GTR! :throwup:
https://www.sau.com.au/forums/topic/50701-awkw-vs-rwkw/#findComment-1010488
Yuko, look at the A/F ratios at 60 kph, no wonder ours guzzles the gas. :headspin:
with the mods i got mine clocked 195awhp (145.411awkw) at 10psi.
What mods are there, sorry I know you mentioned it in another thread but I forgot....
https://www.sau.com.au/forums/topic/50701-awkw-vs-rwkw/#findComment-1011002
Well according to his profile he's got a FMIC and a 3" exhaust... looking at the AFR doesn't look like he's got anything to correct the fuel, and it looks like it would really benefit from it :cheers: Add a bit of boost and it should make a fair bit more power again...
https://www.sau.com.au/forums/topic/50701-awkw-vs-rwkw/#findComment-1011088
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
